Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-23-2009, 04:24 PM
bfedger is on a distinguished road
Question Mazak Ultra650
Hi
I have started operating an Ultra 650 machining center.
I am a G code programmer, and find that I have trouble with M32 controls,and T plus controls . Ther are sub programs nested in a master program, and when the cycle is interupted I dont know where to restart the machine.
Old 01-27-2009, 09:31 PM
psychomill is on a distinguished road
So you're asking how to restart a program? or you simply don't know where in the program to restart the program?
It's just a part..... cutter still goes round and round....
Old 01-28-2009, 09:28 AM
Question
First, I made a mistake. It is an Mplus control. Second,the master contains pallet changes then goes into various sub programs which involve certain machining ops.
I know how to re-start,but I have trouble navigating the sum of the programs if I have to stop a job that is in the middle of a cycle. (flow chart?).
Thanx
bfedger
Old 01-28-2009, 10:23 AM
It depends on how the programs are nested as to whether you can get this back into an AUTO mode with the pallet changes or not. You could just keep jumping (ez to screw up) or simply call up the Main program you need to restart, finish the program, then jump back into the pallet change program to get back into program cycles.
If it's strictly a navigating issue, not much to help with out here. We'd have to see your programs and understand where your stuck at to see how you can get back there. Basically, we need to follow your trail.
Now, depending on why you had to stop (as long as you don't push RESET), you can look on the position page and see where the control is at in the program. Below the "W.No." output you'll also have a sub program number in "( )", the Unit number (or N number for EIA) and sequence (line count from unit start). That can help you figure out which part of the program you're at. Be careful though, simply restarting from a subroutine doesn't necessarily make things all right... especially if its nested from another routine or main (not including pallet program).
Old 01-29-2009, 10:28 AM
ultra 650
Thank You
I will try to decipher wher I am in the program. I must say that I like G code programming with sub routines better. At leat I know where I am.
Mazak T32-2 EIA positiverake Mazak, Mitsubishi, Mazatrol 0 07-01-2008 07:31 PM
Need Help!- Mazak QT-10 T2 manuals --acct w/ mazak? CDTINC Mazak, Mitsubishi, Mazatrol 0 06-30-2008 08:42 AM
mazak m2 racks Mazak, Mitsubishi, Mazatrol 1 06-23-2008 07:12 PM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
Mazak jackson General Metalwork Discussion 65 03-21-2007 10:06 PM
