Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-06-2009, 05:39 PM
Mykal Ward is on a distinguished road
Mazak Laser?
Hey guys,
I have just purchased an older Mazak laser to support our product line. We currently have several other Mazaks (HMC's, VMC,s as well as turning). They are all equipped with Mazatrol controls, which we absolutely LOVE! The old laser we picked up has an L1 control on it.
My question is, will the control system on the laser be similar in use to the other Mazatrol controllers we are using? I guess what I am asking is, will it be a cam based programming system? Please keep in mind that i know NOTHING about laser cutting!
Mike.
......as an afterthought; In the event it is not going to be as simple as my other Mazaks what programming software will I need. We have SolidWorks and MasterCam-10......if that helps?
Edit/Delete Message
Old 01-15-2009, 01:07 AM
Lasercase is on a distinguished road
The L1 is the first Mazak/Panasonic controller after the Fanuc period.
It has lower input units then Mazatrol or L32 controls >Metric 0.01 instead of 0.001
Graphics is pour.
Programming can be done in the same way that you are used to.
You need a postprocessor for correct M codes and subroutine's of course.
The first thing you should do when starting up is saving all machine parameters! (NC/PC)
If you need help let me know.
LaserCase
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
Need Help!- Mazak QT-10 T2 manuals --acct w/ mazak? CDTINC Mazak, Mitsubishi, Mazatrol 0 06-30-2008 08:42 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
