Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-26-2008, 01:13 PM
smts is on a distinguished road
Mazak T32-3 RS-232 communications
I am attempting to hook up RS-232 on an Integrex 40...with a T32-3 control. I have made up the cable..set " I " parameters. before I even plug the cable in and try to send or recieve a program, I get either a 515 error cmt misconnection or a 544 tape reader misconnection error, and then the same thing when I plug the cable in. Anyone have any recommendations to fix this problem Thanks in advance
Old 12-26-2008, 01:56 PM
WayneHill's Avatar
WayneHill is on a distinguished road
What serial wire configuration are you using?
Wayne Hill
www.codemangler.com
Old 12-26-2008, 04:41 PM
serial wiring
mazak (25 pin) pc (25 pin )
1-------------------1
2-------------------3
3-------------------2
4-------------------5
5-------------------4
7-------------------7
I get the error even when the cable is not plugged in...
Old 12-27-2008, 09:32 PM
WayneHill's Avatar
How about wires 6 8 and 20? Are you shorting them together on both sides?
Wayne Hill
www.codemangler.com
Old 12-29-2008, 09:45 AM
mazak
yes, on the mazak side, jumpered 6-8 and then to 20 on pc side...
Old 06-03-2010, 05:02 PM
alejorestrepo85 is on a distinguished road
i have the same problembut i´m using the following cable:
pc 9 pin CNC 25 pin
2--------------2
3--------------3
7--------------5
8--------------4
5--------------7
jump 6, 8, 20 on CNC side only
I want to drip feed a long problem. Can someone help me?
Old 06-03-2010, 05:36 PM
carlos9ibarra is on a distinguished road
i have this configuration in a picture, i hope this can be use.
if you want write to my e-mail and i send you the picture to your mail.
juan_ibarra@steris.com
Need manual for BMC 30/D and ? about communications apylus444 HURCO 3 05-14-2011 11:04 PM
Need Help!- 98 HAAS VF-3 communications jeff@rans Controller & Computer Solutions 8 10-08-2008 01:11 PM
VMC 3016 communications ttorqueshop Fadal 12 11-24-2007 10:23 AM
GibbsCAM communications pounce GibbsCAM 5 03-11-2005 12:03 AM
PDA Communications rfmerrill General Metalwork Discussion 0 02-09-2005 07:03 PM
