Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-21-2008, 06:27 PM
CNC Viking's Avatar
CNC Viking is on a distinguished road
How to set/adjust Z0 in G30??
My Meldas 520 AM use G30 in the Tool Change program and in a special Tool Length Measuring program.
Example:
G91G30Z0M19
I would like to adjust Z0 as I find it a little too low for my ATC. The spindle's tool clamping/unclamping movement pushes (flexes) my umbrella type tool magazine downwards when changing tool and I don't like that at all.
Can someone explain where in the control's menu's one can set or adjust all G30 parameters for 2:nd, 3:rd and 4:th Reference Points.
Old 12-22-2008, 06:02 PM
CNC Viking's Avatar
Come on guys!
There must be lot of people here that can do this blind folded.
Any chance of help?? I really need to fix this.
Old 12-24-2008, 07:52 AM
CNC Viking's Avatar
OK, I finally got it.
Chippy helped me in another thread. He told me to look for the ZP-RTN tab in MACHINE PARAMETERS.
Procedure to set, or modify, the 2:nd, 3:rd and4:th Reference Points (G30P2, P3, P4)
1. Press DIAGN IN/OUT button.
2. Press Menu key under the screen until you can see the option PLC I/F.
3. Press PLC I/F key under the screen.
4. Make settings: DEVICE (1001) DATA ( ) MODE ( M ).
5. Press green INPUT CALC button. You will see no change, but leave it at that.
6. Press TOOL PARAM button.This brings you to the MACHINE PARAMETERS menu which is now open.
7. Press MENU until the ZP-RTN option is visible.
8. Press ZP-RTN key under the screen.
9. Edit P2,P3,P4 settings for X, Y, Z and 4:th axis. The 4:th axis page is not visible unless "4:TH REMOVE" is switched off in the PLC-switch area.
10. Press DIAGN IN/OUT button.
11. Press Menu key under the screen until you can see the option PLC I/F.
12. Press PLC I/F key under the screen.
13. Make settings: DEVICE (1001) DATA ( ) MODE ( U )
14. Press green INPUT CALC button. You will see no change, but leave it at that. This brings you back to normal "USER PARAMETER" status.
As for using the G30 command in programs: My manual says that if there is no Px designation after a G30 command, then the 2:nd Ref Point (P2) is selected anyway.
How do I adjust the backlash S Lovette Shopmaster/Shoptask 3 03-15-2010 01:57 PM
How to adjust rpm on this dc motor kprice1658 General Electronics Discussion 8 10-02-2008 06:55 PM
Z axis how to adjust it cob Mach Mill 1 07-10-2008 04:59 PM
How do I adjust the Gibbs? CNCadmin General Metal Working Machines 20 05-13-2008 06:06 PM
how to adjust Backlash. cnccustom Syil Products 4 11-21-2007 12:28 AM
