Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-12-2008, 01:37 PM
Jcip's Avatar
Jcip is on a distinguished road
Required height for bringing in a Mazak VTC-41
I wanted to find out what the required height for bringing in a Mazak VTC-41 into a garage. I have a 84" opening. I think it will be tight if not impossible get in. I posted a simular post for a haas VF-1
any help would be appreicated
Jim C
Old 12-12-2008, 05:16 PM
1998cor is on a distinguished road
making the haas fit
you can remove the Z-axis motor, gore tube and if needed the counter balane cylinder for extra clearance. The counter ballance cylinder is under pressure so be carfull bu8t it can be done. Call me for more info 818-346-7985 or email John@machineryresources.com
Old 12-13-2008, 06:59 AM
Leelund is on a distinguished road
VTC41 Fit
Operating manual machine specs page says 109.5 inches. I suppose that is to the top of the Z motor or counterbalance which ever is higher. Weight is listed as 8600 pounds. Too close to call without actually measuring. Spec sheet was too large to post, sorry!
Lee
P.S. As with the Haas, you can remove the counterbalance and Z motor but it still is gonna be tight.
Bringing the Art of Scraping into the 21st Century? Oldmanandhistoy Linear and Rotary Motion 107 12-23-2009 01:32 PM
Need Help!- Minimum height required for moving a VF-1 Jcip Haas Mills 7 12-15-2008 12:57 PM
bringing chinese lathe across border ged Mini Lathe 3 07-29-2008 10:35 AM
Bringing on the power fatal-exception Gecko Drives 0 03-21-2008 08:17 PM
Bringing objects together in V19 & general questions rustyolddo BobCad-Cam 1 07-31-2004 09:14 AM
