Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-08-2008, 09:52 AM
shake n bake is on a distinguished road
Thread milling
I have a sqt250m lathe. I was wanting to know if I could thread mill on it and if so how to go about doing it. I have a 27npt pipe thread mill.
Old 12-22-2008, 06:24 PM
Mikiemo is on a distinguished road
thread milling
More likely than not you will need to program with a manual milling program, jsut like gcode except you don't need to turn cutter comp off at the end of the unit. when you go back to straight mazatrol it will do that for you. used the same cycle frequently for just straight helical milling. if you need sample code I can probably dig some up for you.
Mikiemo
Old 01-09-2009, 04:04 AM
Sorry it took so long for a reply. Thanks for your help, I looked into a manual program and was able to get it to work
thread milling help BAD DOG Daewoo/Doosan 1 11-28-2008 12:20 AM
3M and thread milling? teamjnz Fanuc 4 11-03-2008 07:09 PM
Need Help!- Thread Milling on v22 PinMan BobCad-Cam 9 07-28-2008 06:42 AM
thread milling fourperf Fadal 2 11-20-2007 09:32 PM
Milling a thread, CharlieM G-Code Programing 2 10-09-2007 03:05 PM
