Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-05-2008, 10:10 PM
Mazakdude is on a distinguished road
simple stuff
I'm trying to cut a 24 inch spherical radius on the end of a 2.750 diameter shaft. I'm using a t plus control. I have in the past drawn out these kind of things in mastercam and plugged in the required values to avoid the frustration that I always run into. When I try to do a radius I enter x=0 for my center of arc x and z=24 for z arc center. I put in 2.75 for my final x and the ?intersect for the final z, x0 and z0 for my starting points. I've tried rearranging these values but to no use. It always tells me DATA MISSING. This is truly frustrating please help.
Old 12-06-2008, 08:36 AM
sfilippo is on a distinguished road
Mazatrol
Bar Out (General Out)
Convex Arc
Starting Point X = 0.
Starting Point Z = 0.
Finishing Point X = 2.75
Finishing Point Z = 0.039 (-0.039)
Radius = 24.
Be sure and check the graphics to see if this works. I haven't tested it.
You should be able to just run a finish routine to avoid roughing witness marks.
Please Help!! Simple 3-D part not so simple for me eaglegage Mastercam 16 05-15-2008 10:00 AM
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
Need a system to run simple CNC for now, but also some whacky(er) stuff in the future nick mulder General Electronics Discussion 0 02-26-2007 06:09 PM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
