Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-03-2008, 02:26 PM
NellyB is on a distinguished road
mazak Quick Turn
Trying to drill a cross hole
using the live tooling
and the hole is not on center
is there a adjustment?
Old 01-07-2009, 10:43 PM
Michael82 is on a distinguished road
setting the tool data and tool offsets on a mazak live tooling lathe
This is the 1st time I have got a chance to set-up a mazak lathe . If it is anyway possiable can you tell me how to set the tool data then the tool offsets. This machine (Mazak 200mt ) has a y axis and I have never used y before can you help me get the tool data set and the offsets?
Michael
Old 01-08-2009, 04:46 PM
CNCRim's Avatar
Follow the bottom right handside, and just put physical tool information in tool data. The live tool offset is specification manual(it's only reference) the best way is to indicate the spindle the get that number.
If you have tool eye ...... it's pieca a cake, all you need is touch off.
Old 01-23-2009, 01:56 AM
murrayclair is on a distinguished road
Check with an indicator
The turret may be off! Place a dial on the holder and wind the axis back and forth. If the turret is out thats your prob. Take out the tapered pins from the face of the turret loosen the cap screws and reset the turret on center by dialing the inside of a boring bar holder with an indicator mounted on the chuck.
Need Help!- Mazak Quick Turn 15 leaking air? revlimit Mazak, Mitsubishi, Mazatrol 0 11-25-2008 11:04 AM
Need Help!- Mazak Quick Turn 350 T.J Mazak, Mitsubishi, Mazatrol 6 06-09-2008 06:14 PM
Quick Turn 10 Controller FR-SE Rooster Mazak, Mitsubishi, Mazatrol 8 06-07-2008 08:05 AM
Need Help!- Mazak Quick Turn 350 T.J General Metalwork Discussion 0 05-14-2008 06:19 AM
Mazak quick turn nexus 250ms 640t control sidecar82 Mazak, Mitsubishi, Mazatrol 8 04-04-2007 07:07 PM
