Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-24-2008, 03:54 AM
iNUC is on a distinguished road
Meldas-300 series / MNAP L III initialize procedure
Any one here know how to make initialize MNAP-L III for Meldas-300 series ( Lathe)?
Before make ram clear, i need to write down old data first, but I don't know how can I access.
Please advise,
Old 11-25-2008, 08:36 AM
chippy1 is on a distinguished road
Look on your CNC control inside your cabinet. It will be a dark colored box with green and probabky red LED's on it. At the top there should be a label with a model number. Should read M325LG or M325LGV? Please reply to this question. I maybe be able to help.
Chippy
Old 11-25-2008, 09:31 AM
Is your control locked up right now. What are the LED conditions on the CNC in the back? If it's locked up, then you have already lost your parameters. Usually though, most are kept on a E2Prom. However, this control is a little tricky to get back up because of the MNAPIII and the way MHI Zero the machine. This particular control was the oldest model though before they moved to the M325.
Chippy
Old 11-25-2008, 09:48 AM
Meldas 335LG
The problem is I can not access in MNAP ( Showing Mnap L III but can not go inside ), no red led on PCB.
Old 11-25-2008, 10:03 AM
On this control I believe there is a disk on the left hand side on the CNC in the cabinet. When you power this machine up and then the CNC, do you see this disk loading. There usually is a red or green LED that turns on, on the disk drive. It should stay on for about a minute I woulod say while it loads the S/W.
Chippy
Old 11-25-2008, 10:08 AM
Meldas 335LG
When I power up and press MNAP screen, there is only FLD LOADING, after 30 second MNAP L III is show on CRT.
Old 11-25-2008, 10:39 AM
Can you tell me if this is a MTC8A or B? Did you say you have no alarms on the diagnostic page also? I don't want you to initialize if possible. You can do more damage then good by doing this if you don't have the parameters for this machine. Hopefully most are stored on the E2Prom.
It maybe that you just have a bad floppy disk or floppy itself.
Chippy
Old 11-25-2008, 11:08 AM
Meldas 335LG
How do I know MTC8A or B? We have no parameter for MNAP L III and ATOM paramerter.
Any method for checking?
Old 11-25-2008, 11:26 AM
Look at the tag on the machine where the serial number is. It should tell you there. You may have to walk around the machine to find it.
Chippy
Old 04-22-2010, 03:48 PM
ekim_hol is on a distinguished road
M-NAP DISK?
I have a mitusbishi M-V70D with a Meldas control, The control is a 335(not sure on the letters, will have to look it up) but the M-NAP function has never worked as the previous owners did not use it and for some reason removed the diak then lost it. How can i get a copy of this?
  #11   Ban this user!
Old 04-22-2010, 05:16 PM
You will need to contact Mitsubishi to obtain that disk. It cannot be copied on a PC. There is a special procedure to make a copy and only Mitsubishi can perform that task. The OS is different then windows, linux, etc.
Regards,
Chippy
Need Help!- QT10nT-2 re-initialize my controller and installing new parameters STEVEN911 Mazak, Mitsubishi, Mazatrol 2 11-05-2008 05:37 PM
Procedure for BMU 6TA SGARCIAM Fanuc 1 10-25-2008 12:38 PM
Need Help!- Meldas-335LG Ram Clear procedure needs iNUC Mazak, Mitsubishi, Mazatrol 0 10-21-2008 10:17 AM
meldas 50 Series nastek Mazak, Mitsubishi, Mazatrol 5 12-31-2006 09:32 PM
