Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-21-2008, 06:37 AM
apylus444 is on a distinguished road
dnc inactive on M2 control
Hello,
I am set up to load EIA ISO programs to my M2 control. I push TAPE I/O, it brings up the menu and works fine. I now have a program that is to large for the available memory, I want to run it DNC. The problem is that from the PROGRAM FILE menu, where the DNC I/O and the TAPE I/O keys are found, I push DNC I/O and nothing happens. I wonder is there a parameter that needs changed to activate it?
Thanks,
Apylus444
Old 11-21-2008, 07:16 AM
MrMazak is on a distinguished road
DNC is an option that includes a board and is not used for "spoon feeding" large programs. The parameter to turn it on if you have the board installed is YO4 Bit 0 0=DNC OFF 1=DNC ON I will check my M2 data t see if I have more info.
Old 11-21-2008, 07:31 AM
Attached is some more DNC info more Mazak service dept bulletins.
Old 11-21-2008, 08:09 AM
Thank you Mr Mazak you are always helpful.
Old 11-21-2008, 08:28 AM
Y04 changed but still having trouble
MrMazak you are correct, changing Y04 to 1 enabled me tom bring up the dnc screen. I don't understand the process from there, however. I tried LOAD HOST>NC, it asks for piece number. When loading in tape mode you can just push start and it searches and finds it. I tried that and it gives a message stating the DESIGNATED DATA NOT FOUND. I tried entering a number and it just locks up the control.
When you say that it's not for "spoon feeding," not sure what you mean. I want to activate the DNC, go to AUTO mode and push start and run the program off the computer. Any thoughts on what I'm missing? Thanks again.
Old 12-01-2008, 07:04 AM
Man was I overcomplicating it...all you have to do is push AUTO and F2 at the same time. Be in the command screen and push cycle start. MrMazak its interesting that worked while Y04 was still set at zero. I don't understand but anyway I'm happy since I can finally get some work done!
Need Help!- Seig x2 Speed Control and c6 Control Board skmetal7 Benchtop Machines 2 04-21-2008 03:17 PM
15i control help for (AiCC) (hpcc) high precision contour control programming gibbsmaster Fanuc 2 12-28-2007 09:57 AM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 09:46 PM
BobCADCAM Layer Control / Snap Control jonbanquer BobCad-Cam 0 01-21-2006 03:10 PM
