Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-12-2008, 03:36 PM
williams002 is on a distinguished road
Need Help
I have a Mazak qt 20 that keeps tripping the z axis soft limit while trying to tool change. I only have this problem when I run longer parts. Can anyone please help me with this?
Williams002
Old 11-12-2008, 04:13 PM
MrMazak is on a distinguished road
Check the TOOL SET page one of your tools is set very long and moving the Z to the Index Position and going past the stroke limit Z If tool sets are ok change the index position parameter to X HOME Z HOME and that should fix it. The parameter changes with the control type and is in the parameter book, maybe P8 for the T1-2 P17 for T32-640. I don't have the manuals handy so be carefull changing things.
Old 11-12-2008, 04:51 PM
Thanks for the reply,
I tried to zero out all of my tool offsets except for the two I was using, and they are approx. -15. inches and know when i try to run it is worse. I was about 1 1/2 inches off know i am about 8 inches off. the correct parameter is p17 and I have it set to 1 which should send x home and z to a clearance position. any further help would be help full.
thankx,
Williams002
Old 11-12-2008, 05:01 PM
Mrmazak,
Thanks your your help i was able to get it to work. by putting the same offsets in all the pockets.
Thanks again,
Willliams002
