Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-03-2008, 02:25 PM
cr500 is on a distinguished road
Question mazatrol thread milling
I have a 2001 mazak fusion 640M and I need a program example for a 1.250 x 11.5 NPT for thread milling. I know to start with manual program and put the tool info in, but not sure after that. Can anyone help me.
Old 11-15-2008, 12:58 PM
ilya9999 is on a distinguished road
tapered thread milling
I think there's no solution in Mazatrol for tapered thread milling, also with manual programming. Only ISO programming with simultanuly moving for three axes
Old 11-15-2008, 11:17 PM
WayneHill's Avatar
WayneHill is on a distinguished road
http://www.cncci.com/resources/tips/taper%20thread.htm
Wayne Hill
www.codemangler.com
Old 11-17-2008, 07:38 AM
MrMazak is on a distinguished road
Attached is a Mazatrol Manual Unit sample for a 1-1/4NPT thread using a 3/4 single point tool. Mazatrol tool data controls the cutter offset. I did not test this program so be careful if you run it.
Old 12-05-2008, 09:06 AM
Smile Everything is OK I got it.
It is so simple in mazatrol with just 5 G codes.
Old 12-22-2008, 06:28 PM
Mikiemo is on a distinguished road
pipe threads
the only way i've been able to thread mill pipe threads is with an inserted thread mill that has an insert as long as the thread. I did this making gas pump handles for a guy. thousands of them on a v414 with fusion 640m, and a-axis.
Mikiemo
Old 01-23-2009, 02:22 AM
murrayclair is on a distinguished road
Thread Mill
You can use Mazatrol Manual Program to call the tool, start the spindle and position the tool then jumpout of Mazatrol into a EIA program and write a straight line incremental polar movement, sayat 5 degrees from your start position about the centre with X, Y, and Z movement and repeat this 71 times as a sub routine, then put that sub into another and repeat for the number of revolutions that you need.
Old 04-13-2009, 08:48 AM
newguy81 is on a distinguished road
Did you get get this solved? The answers that I have read here are all long and more difficult than need be. Simple manual program is all that's needed. We cut tapered threads all day everyday. Best thread mill is tool-flo. 2" NPT 8 sec start to finish.
Mazatrol variable thread lead? extanker59 Mazak, Mitsubishi, Mazatrol 0 06-24-2008 01:24 PM
thread milling fourperf Fadal 2 11-20-2007 09:32 PM
Mazatrol T Plus thread cycle in synch? Castle1 Mazak, Mitsubishi, Mazatrol 2 03-25-2007 10:22 PM
