Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-07-2008, 12:40 PM
Mark Green is on a distinguished road
Mazatrol T1 on Quickturn 20 - Lost parameters!
Hi All,
Ok you have to bear wth me because I am new to CNC machines.
We have a QT20 with a T1 control system. It has been switched off for a year or so and the battery has gone flat and it seems all parameters have been lost.
When we first switched it on we had 2 battery errors (cant remember exactly) "F Emergency Stop" "Overtravel +Z" "Overtravel -Z" "Overtravel X"
I figured out to push the OT release button. This let me move the X axis and the fault has gone. With this pushed I was also able to jog the chuck and rotate the tool holders. At no time did Z axis move.
Now the OT release has no effect and we are stuck with E-stop and both Z overtravel errors. Nothing will move.
It seems that we have to enter all parameters by hand? but I can't find this in any of the manuals we have. (we have programmng, user, & maintenance)
Any help greatly appreciated.
Mark
Old 11-07-2008, 12:58 PM
Al_The_Man's Avatar
Do you have the parameter listing for your machine? If you get any asterisks anywhere, it is best to clear memory, I can see if I can put it in PDF format.
But if you have them, just go to the 4 parameter pages and enter the parameters you have, the OP, option parameters have to be entered with the parity bit in the least significant position , IOW if the OP parameter is 01010001 you need to enter a 3 at the end, i.e. 010100013.
Hopefully you have the chuck barrier etc No's.
Don't forget the new battery
Old 11-07-2008, 01:30 PM
Yes I have lots of asterisks and many parameters show 65280.
I have not found the parameter list but I will have a good look through all the paperwork on Saturday. Will this list include the Chuck Barrier etc. or is this different?
How do I reset the memory?
many thanks
Old 11-07-2008, 01:38 PM
Al_The_Man's Avatar
If you find the parameter list, it should also have the tool offsets and chuck barrier etc.
Look in the enclosure pockets.
I will see if I can round up a typical T1 parameters, and the procedure, I also have the parameter definitions, except the options.
Old 11-07-2008, 07:02 PM
bigbobomb is on a distinguished road
Originally Posted by Mark Green View Post
Hi All,
Mark
Mark, If you give me an email address I can send you the procedure to re-initialize your control along with memory clear.
Old 11-08-2008, 02:47 AM
Thanks bigbobomb I have PM'd you.
I really appreciate the help I'm getting here.
Old 11-08-2008, 09:47 AM
Al_The_Man's Avatar
I take it you do not need them now?
Old 11-08-2008, 06:46 PM
I sent you an email
Old 11-10-2008, 02:50 AM
OK I am making progress.
I have found the original parameters for our machine. (hidden away at the back of the tooling cupboard)
Bob sent me instructions for initialising T2/T3. Does anyone know for sure if this will work for T1?
Does anyone have specific instruction for T1?
thanks,
Mark
Old 11-10-2008, 09:49 AM
Al_The_Man's Avatar
T1 parameters and procedure sent.
  #11   Ban this user!
Old 11-11-2008, 05:36 AM
Thanks Al, a great help.
However - I still have no luck getting the machine running!
There is still F-Emergency stop and Z Overtravel & -Z Overtravel alarms.
The O/T button has no effect in allowing the machine to function.
Nothing at all works. Not even the light on/off.
Any ideas?
We do not have any tool or barrier data so I have entered the values from the screenshot in the user manual. Is this critical at this stage?
Old 11-11-2008, 07:39 AM
Al_The_Man's Avatar
Are there any alarm number associated with them?
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
Problem programming my Mazak QuickTurn 15 revlimit Mazak, Mitsubishi, Mazatrol 3 10-23-2008 08:28 PM
Newbie- What is the GL/CF button used for on a Quickturn Nexus 300? Y_punishment Mazak, Mitsubishi, Mazatrol 2 06-06-2008 01:23 PM
Hyundai Quickturn 8N Control Help hawkeye31202 Hyundai Kia machine 2 05-01-2008 12:50 PM
mazak t32-2, quickturn 8n Enda Mazak, Mitsubishi, Mazatrol 3 02-09-2006 04:00 PM
