Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-06-2008, 11:28 AM
mbmmachining is on a distinguished road
chuck working now is not
qt-10 universal 1984 t1 control
chuck was working fine then yesterday norning stopped working?
pedal switch is fine i checked.
air pressure fine.
what could it be?
any suggestions??
Old 11-06-2008, 01:36 PM
bigbobomb is on a distinguished road
could be a bad air soleniod
Old 11-06-2008, 03:37 PM
i thought so too.
is there any way to check it?
Old 11-07-2008, 11:32 AM
solenpid is fine.it works
what else could it be?
Old 11-07-2008, 06:59 PM
are you sure that the drawbar or tube is moving in and out?
Old 11-07-2008, 09:23 PM
nothing moves outside or in
Old 11-09-2008, 06:34 AM
sfilippo is on a distinguished road
Have you tried to open and close the chuck using the MDI M-code input option?
Old 11-10-2008, 09:10 AM
i wish i could.
this machine for some reason doesn't have mdi or test option.
Old 11-10-2008, 05:56 PM
Leelund is on a distinguished road
Mechanical bind or siezure of the chuck jaws or the rotating cylinder piston is my next guess. At this point, probably going to have to remove the cylinder and draw bar. Test by hooking back up to the air lines and see if it moves left and right or in and out. If it's ok, move to the chuck and see if the chuck jaws move by sliding the center ring left and right. You might tap on the jaws with a rubber hammer and see if they move. The operating circuit works to the solenoid right? Only thing left to do is tear down. What brand and size is the air chuck? I may be able to aquire drawings. My 2 cents worth.
Lee.
P.S. Before doing the above, have you tried greasing the jaws and trying to operate back and forth at maximum air pressure?
Chuck nmcdairmant General Business Practices and Pricing 0 09-08-2008 10:18 AM
2 Jaw Chuck HBFixedGear General Metalwork Discussion 0 10-05-2007 03:14 PM
Q: Need 5C Chuck Deviant Mini Lathe 1 04-23-2007 03:15 PM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
air chuck bbrreid Mechanical Calculations/Engineering Design 4 11-20-2005 07:44 PM
