Results 1 to 2 of 2
Thread: Mitsubishi Meldas 520 AMR RS232 Cable pinout??
    Registered CNC Viking's Avatar
    May 2008
    Sweden
    Smile Mitsubishi Meldas 520 AMR RS232 Cable pinout??
    I have a 1996 Feeler FV-800 VMC with Mitsubishi Meldas 520 AMR control.
    It has a RS 232 port and I intend to connect it to any of my PC's via a Ethernet switch and the Ethernet-RS232 adapter that I already have in the CNC's cabinet. Which is the best way to go, Software handshake or Hardware handshake. Would appreciate cable pinouts and parameter settings. I intend to use a CAM program, maybe VM 6 Pro, and I assume that it has a DNC program bundled. By the way, which one is it ?
    Aug 2007
    Have you got it working yet? I've wired mine for hardware flow control. But, I know the Meldas uses XON XOFF which is software flow control. So, I'm using both, but you should be able to wire your connector so the machine and computer (or ethernet adapter) both ignore hardware (clear to send is always high, etc) Let me know if you need some diagrams on how to wire, I have them somewhere.
  1. Mitsubishi Meldas 300-V
    By firestaromega in forum Computers and Networking
    Last Post: 06-28-2012, 02:18 AM
  2. Mitsubishi Meldas L3
    By hutch07 in forum General Metalwork Discussion
    Last Post: 09-18-2010, 06:31 AM
  3. Mitsubishi Meldas L1
    By LocTite98 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 01-30-2008, 02:26 PM
  4. Mitsubishi Meldas 60S
    By BKCOM in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 08-29-2007, 03:07 AM
  5. ask for help about connecting pc to mitsubishi meldas 50s
    By samhai in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-16-2007, 04:39 PM
