| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| I'm trying to find a drawing/wiring chart for the serial port on a vk45 I have looked around the internet and can't seem to find one I'm trying to help a friend by building a cable for him and understand the PC end and have an understanding of handshaking Thanks to all |
| I have a customer that has some of these Hitachi VK45's and I could probabally get it Monday, Here is a link in the mean time, (they also have a free single PC/machine) DNC program. http://www.cadem.com/ncnet/ncnet_dncdetails-41.htm Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I'll see what I can do, it is probabally going to be a standard RS232 25p 'D' conn. I think he uses the 3 wire (jumpered handshake) mode. Al
| Is that pin 1 of a 9p D, or pin 1 of 25p? Pin one of the 25 pin type is usually ground or shield, and not generally used. On 9 pin D pin one is DCD. Al
Here is the VK45 serial port info, . I guess the VK45 port is not standard after all. VK45___ PC 3------2 SD 5------3 RD 7------4 RTS 9------5 CTS 14-----20 DTR 15-----8 DCD 13-----7 SG 1------1 FRAME GND Al
| Thank you for checking, I hate to ask 1 more thing, his book has a listingfor location 305 there is no table/location for 7 or 8 bits or even odd parity the is a listing for stop bit. the 305 location has a table the showes differant baud rates but only one block for baud, am I to assume the right 4 bits are the hold baud rate setting or does the type of machine only work at 600 baud I want to say thank you VERY much for you help, TJ |
| I will see what I can find out tomorrow. Al
#11
| Hi Al, New on this Forum, machine and communication. I have a 1988 VK-45 with the Seike Seicos M2 controller and intend to use a 25 to 9 pin serial. Can you maybe help me? Please, please! I Need pin wire info, stop bit, parity, data bit, flow control, and Xon/Xoff character information if you should have it. You are truely the Al Man in my book, if you can help me. Tnx a bunch. E.T. |
#12
| If you use the three wire cable,( XON/XOFF HS) and the VK has a 25pin D connector out to the front then, on the CNC side 6,8,& 20 are jumpered 4 & 5 are jumpered, on the 9pin 1, 4 & 6 and pins 7 & 8 are jumpered the 3 wire connection between D connectors: CNC -----PC 2---------2 3---------3 7---------5 Set both ends to 9600baud 7 bits, even parity, 1 stop bit. What communication program are you using? Al.
| Adding a serial port - please comment | DareBee | Machine Problems, Solutions , Wireless DNC, serial port | 11 | 03-22-2006 08:26 AM |
| pic chip SERIAL to step/dir and controll | berin | Open Source Controller Boards | 13 | 02-18-2005 06:23 PM |
| Serial or Parallel port drive | Max | General Electronics Discussion | 8 | 11-02-2004 01:20 AM |
| CAD/CAM Serial Control Software | AndG | General CAM Discussion | 2 | 05-10-2004 08:43 PM |
| Using A Laptop Without Serial Port | mtech | Computers and Networking | 6 | 08-17-2003 09:58 AM |
