Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-28-2004, 05:01 AM
sleepless1 is on a distinguished road
More Comms problems
I need help please!!!
I have Bridgeport VMC460/12 running Fanuc OMate M (please dont ask if it is an a, b, or c model as i have no idea and dont know really where to look to find out) The problem is when i connect to PC i can send file to PC from the CNC but cannot then send the same file back. I have had an electronics friend of mine to have a look, he checked the cableing and he said that was fine. Then he put a RS232 checker box on the CNC end of the cable and that lit up like a christmas tree proving the data was being passed throught the cable.
Finally he went into the 'hexadecimal' data and found out that the control needs end of line data as 'LF CR' (line feed carriage return) but the PC is sending it out as CR LF ( or vice versa).
Can someone shed some light?
Cheers
Old 10-28-2004, 12:00 PM
Rekd's Avatar
Rekd is on a distinguished road
There should be settings in the software you're using to add/remove/modify CR/LF's.
What are you using?
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 10-28-2004, 02:46 PM
Al_The_Man's Avatar
Does the control end indicate an error of any kind? or does it just wait there in the recieve mode? Here is a previous link http://cnczone.com/forums/showthread.php?t=4399 on the Zone that covers some of the points of comunicating with the Fanus0 mate.
Al
4020 4th axis problems little bubba Fadal 3 06-13-2005 10:08 PM
Cincinnati 5VC750 acramatic 900V2 problems motordude Machine Problems, Solutions , Wireless DNC, serial port 5 03-12-2005 02:16 AM
mystifying 320 problems senor J. Gecko Drives 6 01-19-2005 08:40 PM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
Accuracy problems i228208 General CAM Discussion 26 05-30-2004 02:31 PM
