| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| Sounds like X axis is interlocked for some reason. Search X interlock in ladders to see what the machine is waiting on. Maybe not all axis zero returned initially? ATC not parked or home? Table unclamped? Pallet unclamped? Tool measure arm extended? Something goofy like that. Last edited by Leelund; 10-14-2008 at 04:49 PM. |
If your machine is a lathe then G01 X-45. F10./F.01 will not move the machine unless the spindle is moving because you are in IPR (G99) try (IPM) G98 G01 X-45. F10. If this is a mill the it could be the interlock, door open feed overide turn down, chuck not clamped |
| Just as I thought it was something simple: I was putting the S and M3 in the same block as the G01 X-20 F25. Too much for it, I guess, because I tried entering just the S and M3, cycle start to turn it on, then the G01 X-20 F25 seperately and pushed start and it worked fine. Thanks for the replies. |
| Need to replace Dynapath 20 control with new control | Cycle Start | Knee Vertical Mills | 3 | 08-08-2010 03:14 PM |
| Need Help!- Seig x2 Speed Control and c6 Control Board | skmetal7 | Benchtop Machines | 2 | 04-21-2008 03:17 PM |
| 15i control help for (AiCC) (hpcc) high precision contour control programming | gibbsmaster | Fanuc | 2 | 12-28-2007 09:57 AM |
| Using Flashcut CNC Spindle rotate card control to control laser power | pyroplotter | FlashCut CNC | 0 | 10-15-2007 09:46 PM |
| BobCADCAM Layer Control / Snap Control | jonbanquer | BobCad-Cam | 0 | 01-21-2006 03:10 PM |
