Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-13-2008, 07:32 PM
carbidecraters's Avatar
carbidecraters is on a distinguished road
QT10 hi/low shift mechansim
This QT10 (a long drawn out story of personal failure ) has a disk style high low. It uses a pneumatic piston to move the gear disk in and out. What is happening (I think) is that we are hearing a grind sometimes when in gear. The gear teeth are in good shape right now and I dont want them to get ruined. The shifter moves fine and it moves the double gear disk from hi to low. I think that the air selenoid is bleeding off pressure allowing the force on the piston to get weak then letting the gear disks to fall off each other. So my questions are
1. Does anyone have a mechanical breakdown of a 1986 QT10 hi/low mechanism?
2. Has anyone had a similar issue?
We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
Old 10-13-2008, 08:44 PM
Ok so we reubild the air selenoid and now we are getting a pulsing back and forth of the spindle. I think that maybe the shaft is messed up and both pullies are trying to drive the spindle and that tells the encoder is doesnt have the right rpm.
Man I wish some guys with older QT10s would chime in on this website
Old 10-14-2008, 04:42 AM
Leelund is on a distinguished road
Answers
1.See PDF
2.No experience with gearbox.
Old 10-14-2008, 09:57 AM
WOW thats it! Do you have the exploded view...or is there an exploded view?
MAZAK QT10 & BAR PULLER paul wilcox Mazak, Mitsubishi, Mazatrol 5 05-08-2009 12:39 PM
Need Help!- MAZAK QT10 T-2 STEVEN911 Mazak, Mitsubishi, Mazatrol 3 10-05-2008 08:21 AM
problem with mazak qt10 t1 diz Mazak, Mitsubishi, Mazatrol 16 11-12-2007 10:24 AM
Mazatrol t1 qt10 cpu problem diz Mazak, Mitsubishi, Mazatrol 0 10-17-2007 07:29 AM
Forklift ran into our little QT10..help! carbidecraters Mazak, Mitsubishi, Mazatrol 6 07-19-2007 08:15 AM
