Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-07-2008, 02:01 PM
use2machine is on a distinguished road
Part inspection using Mazatrol
We are wondering if there is a way to use the probe in a mazak to find deviations for hole locations in a different way than just probing a hole and using the numbers from the part origin wpc and the hole probe wpc to calculate this. They are looking for a feature like the toshiba bars we have can do where it will probe a hole and tell you how the hole deviates from where it is programmed. I hope I worded this so it makes sense. Thanks.
Old 10-17-2008, 07:57 AM
inflateable is on a distinguished road
I don't think you can do this from within mazatrol, though you can with g-code. The values from the probe are sent to an offset value, which you can then compare with the ideal diameter. Write a macro to compare the two and send the difference to your tool offset value, and it will (should) be self-correcting.
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
Inspection Routings? pp-TG CNCzone Club House 3 07-11-2008 08:14 AM
Inspection reports 1947Hack Calibration & Measurement 2 01-16-2008 06:59 AM
Mazak VTC-41 w/Mazatrol EIA - No Part Origin lfdgonzalez Mazak, Mitsubishi, Mazatrol 1 08-22-2007 10:34 PM
Used machine inspection TR MFG Fanuc 1 03-02-2006 08:48 AM
