Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-06-2008, 07:48 PM
compuslave is on a distinguished road
Mazak M32-Parity H Error
Hey guys. I have done some searching on the forum and will continue to search but I really need to fix this. Our shop recently bought mastercam and I am having some trouble communicating with our mazak m32 control. All parameters are matched and I can send programs from the control to the pc with no problem but reversing that is a whole different story. I get either a 556 Parity H Error or a 'change paper type' error. Any help would be greatly appreciated.
Thanks.
Old 10-07-2008, 08:05 AM
Okay the main error is the infamous 551 change paper type. I can send gcode programs to the computer fine everytime but sending them back I get this error no matter what I change. I have checked the cable and everything seems fine. Any ideas?
Old 01-23-2009, 02:45 AM
murrayclair is on a distinguished road
M32 communication
We had this prob years ago. Mazatrol as I recall counts parity as a data bit therefore you need to have 8 data bits set on your PC and 7 in the M32 parameters. Ask your Mazak service guy he has the page in his service manual.
You would never guess to do this yourself because it seems wrong but trust me.
Old 01-29-2009, 06:03 PM
gm3211 is on a distinguished road
Yes, the Mazaks do need different settings for communication, for example:
8,None, 1 at CNC and then 7, 2, Even at the PC.
Try that and if does not work, give me a call and I will locate the documentation we have.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
Old 02-04-2009, 03:25 PM
Multi-DNC_user is on a distinguished road
Yes that is an infamous error when the settings are incorrect. What system are you using to transfer the Gcode programs through?
We have a Multi-DNC system to do our transferring, and it has settings in it that caused the Mazaks to give the errors.
Or did you fix the problem already??
10T Ram Parity Error grease Fanuc 3 01-23-2011 05:22 AM
mazatrol T4 ram parity error ddareddevil Mazak, Mitsubishi, Mazatrol 8 10-25-2010 07:35 PM
Ram Parity Error rags Fanuc 14 12-19-2008 02:03 PM
Need Help!- Mazatrol T32 - PARITY ERROR maro Mazak, Mitsubishi, Mazatrol 0 06-25-2008 05:53 PM
Fanuc 0M-C --- 914 Ram parity error rajappa Fanuc 4 06-10-2008 10:17 PM
