Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-06-2008, 06:25 PM
CDTINC is on a distinguished road
Stupid simple but??
We have a an Old mazak QT10 that we acquired with a t2 controller. We are learning the mazak language and that seems to be doing well. We are working on a program to drill a hole but the drill keeps coming out offset apparently by half the width of the drill bit. I can't seem to find where to change this.
I can change the direction it is offset by touching off on the top or the bottom. I know this is porblably simple but can anyone help me out here. I can't seem to find it in the book.
Scott
Old 10-06-2008, 07:50 PM
compuslave is on a distinguished road
Do you have a parameter book?
Old 10-07-2008, 07:52 AM
cut more is on a distinguished road
Drill offset
Hello scott,
What g code are you using to drill the hole?
Cutmore
Old 10-07-2008, 07:55 AM
No I don't have a parameter book. Do you think that it is a parameter problem?
Scott
Old 10-07-2008, 08:05 AM
We are using the mazatrol language.
Originally Posted by cut more View Post
Hello scott,
Cutmore
Old 10-07-2008, 10:44 AM
Yes, the retract amount defaults are set in the parameters, atleast on my M32. You should be able to find a list of your parameters online. I'm not familiar with mazatrol so I can't speculate as to what the problem may be with your program.
Just sounds like a parameter too me.
Old 10-08-2008, 08:06 AM
Thanks for the help. We are just compensating for it in the tool offset table. I guess I just assumed that if I set the tool up as a drill then the offset for the x axis would have been preset to the correct zero. Apparently not.
Scott
Old 10-08-2008, 02:33 PM
Captdave is on a distinguished road
Scott-
If all your trying to do is set the tool to X0, go to the tool data page 1, select the tool# X position then use the increment button and then add/subtract the distance offset to bring it back to X0.
Also, on tool data 2, insure that the correct drill diameter is listed.
Hope this helps.
Old 10-19-2008, 12:10 PM
SQT18MS is on a distinguished road
Sounds like the machine things youre drill are an internal turning tool, that exact thing happens when this is wrong in the tooldata 2
Also have you set the standard value for the drill holder?
On my Mazak SQT18MS Mark IIthe standard ofset for drill/internal turning holder are -320mm
You should check both theese things, hope this helps.
On tool data 2 its the first thing you choose in the toll line for the toll you are setting the data for.
Old 10-19-2008, 12:13 PM
Ah, just too mention it, if you only change the diameter of the drill to the current diameter of the drill, but dont change the tool type to a drill, the machine thinks the drill size are the actual nose radius of the turning tool, therefore the tool gets out of center by about half its size
  #11   Ban this user!
Old 10-27-2008, 07:18 AM
pikkipeople is on a distinguished road
mazak user
do not set the x axis with the tool eye on drills only.
it does not matter what size drill you use the x distance is always the same
for example my mazak sqt 8 is 170mm this is the fixed distane from home to the centerline of the chuck.
hope this helps
  #12   Ban this user!
Old 10-27-2008, 09:55 AM
Rich S is on a distinguished road
I ran a QT-10 for years. If the tool is not coming down to X center it is because of one fo two things:
1)The tool is not defined correctly
2)The X-offset is not correct (-10.5")
Any center cutting tool should be -10.5 if your home position is correct. If it is not, let me know and I will give you the parameter to fix it. To check to see if it is correct, put an indicator in the chuck and indicate one of the #2 holders on center. The machine postion should read -10.5 or very close to it. If it does not, let me know. Also, what is the X-value when the machine is drilling without your offset in?
New Machine Build- Maybe a stupid question haroldj Stepper Motors and Drives 1 04-24-2008 01:17 PM
probably a stupid question mad.sculpture Linear and Rotary Motion 4 10-09-2007 04:55 PM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
Before I do anything stupid... runnoahrun Hobbycnc (Products) 2 04-15-2005 05:24 PM
New here, 1st stupid question! FXRocket General Metal Working Machines 4 11-03-2004 09:04 PM
