Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-05-2008, 12:01 PM
J&RMachine is on a distinguished road
Mazatrol t plus ?
I need to be able to program the machining of the inside profile of this 8" dia. Brake wheel for an over head crane. These wheels are cast but just need to be cleaned up on the inside to make balancing easier.
WE have tried using "copy face" with a grooving tool mounted in a special homemade tool holder that holds the tool parrallel to the z-axis. The problem with this is that it starts cutting at the rim of the brakewheel and follows the profile but cuts air from the hub out to z zero. We would like it to start at the hub and follow the contour out to the rim. Does anyone know how to program this and a possibly have a better tool recommendation? Attached is a dxf file of a cut away view of the brakewheel.
Thanks for any help.
Old 10-09-2008, 01:01 PM
TRANSATOOL is on a distinguished road
T-PLUS
GEN IN
GENERAL INNER DIAMETER
SPECIFY START X, FINISH X
START Z , FINISH Z
ANYOTHER QUESTIONS EMAIL TRANSATOOL@AOL.COM
Old 10-13-2008, 12:01 AM
CNCRim's Avatar
Bar Face should work as well........ define stock boundery then it won't cut air.
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
mazatrol cam M2 spickett Mazak, Mitsubishi, Mazatrol 3 03-25-2008 07:34 AM
old Mazatrol Cam T-2 to pc? 4x4 General Metalwork Discussion 1 10-09-2007 05:59 AM
Mazatrol MT Pro wawankot Mazak, Mitsubishi, Mazatrol 1 08-11-2006 11:01 PM
does m-cam do mazatrol? underdog Mastercam 2 10-11-2005 09:30 PM
