Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-04-2008, 08:52 PM
STEVEN911 is on a distinguished road
MAZAK QT10 T-2
i BOUGHT A QT10 T-2 1986 year model it had the frse out of it i sent had rebuilt i installed it powerd machine up hyd pump does not come on when i power up controller also machine sat for 5 years so with that being said
it has some error codes
131 illega param m1-m12
150 illeagal pocket
442 chuck barrier malfunction
443 tailstock barrier malfunction
? 1 backup battery wipe out memory
? 2 were and how do i load param back into machine
and were do i get param
check my picture out
any help would be great full thanks Steven
Old 10-04-2008, 09:58 PM
Al_The_Man's Avatar
It looks as you have definitely lost parameters, the memory has to be cleared then the parameters re-entered.
Any time you see an asterisk on the screen, this is a give away.
You may have to contact Mazak with the model and serial# to obtain the originals.
Hydraulics will not come on until this is done.
As a last resort, they can be loaded manually when you get them.
Old 10-05-2008, 07:35 AM
bigbobomb is on a distinguished road
150 illeagal pocket
You DEFINITLY lost parameters and you will most likely have to re-initializyour control. Look in your electrical cabinet on one of the doors to see of you have a hard copy of your parameters.
Old 10-05-2008, 08:21 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Made in 1986? You should also replace the controls batteries.
Wayne Hill
www.codemangler.com
MAZAK QT10 & BAR PULLER paul wilcox Mazak, Mitsubishi, Mazatrol 5 05-08-2009 12:39 PM
qt10 spindle moves back and forth carbidecraters Mazak, Mitsubishi, Mazatrol 23 10-04-2008 07:54 AM
problem with mazak qt10 t1 diz Mazak, Mitsubishi, Mazatrol 16 11-12-2007 10:24 AM
Mazatrol t1 qt10 cpu problem diz Mazak, Mitsubishi, Mazatrol 0 10-17-2007 07:29 AM
Forklift ran into our little QT10..help! carbidecraters Mazak, Mitsubishi, Mazatrol 6 07-19-2007 08:15 AM
