Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-01-2008, 12:25 PM
apylus444 is on a distinguished road
M2: program restart eia/iso
Do any of you know a way to restart an eia/iso program, only not from the beginning? For instance when running a rougher and finisher, then wanting to only repeat running the finisher. I thought maybe one could call up a 'N' block or something. Thanks for any help.
Old 10-01-2008, 12:36 PM
I got the answer from Mazak Applications: Auto>Restart>Leave seq # blank push input>block # enter N value> enter subprogram if necessary or leave blank and input> start
Old 10-01-2008, 02:29 PM
kotten1 is on a distinguished road
Hi!
When you set M2 in EIA / ISO mode you hold memory button (or maybe it be called run)
And F2 button in.
But how are you doing when you want to set the machine back to MAZATROL mode?
Regards
Kotten1
Old 10-02-2008, 02:19 PM
I am not sure what you mean. If I'm programming at the machine it asks me (after entering a new work number) if I want to program in eia/iso or mazatrol. I select my choice and move on.
When using cad cam I program with the eia iso and just load it, it automatically sets the machine accordingly. I don't know if this helps or maybe I misunderstood the question.
apylus444
Old 10-03-2008, 04:28 PM
Yes it was maybe a stupid question.
I have find it out now .
When I’m in iso mode I just have to turn of the F2 button, otherwise I can’t
Program a new program in the machine..
Old 10-06-2008, 07:07 PM
Bill Johns is on a distinguished road
On the mazaks I run, goto eia iso moniter, search the point to start ie before the tool change and prep stuff. Then push the non modal restart and its ready to cycle start.
Need Help!- Program restart issues HTC400 M-Plus MJMark Mazak, Mitsubishi, Mazatrol 3 09-16-2008 10:36 AM
Newbie- Restart with sub programs Phil S Okuma 6 03-19-2008 05:33 AM
Program Restart in mid program? Donkey Hotey Haas Lathes 16 03-18-2008 02:19 PM
Mid program restart HuFlungDung Haas Mills 4 06-26-2007 04:32 PM
Restart of integrex eia program with dual turrets Bobc007 Mazak, Mitsubishi, Mazatrol 3 04-01-2007 07:43 PM
