Results 1 to 4 of 4
Thread: Strange MAzatrol / EIA-ISO issue
    Sep 2008
    Ireland
    Question Strange MAzatrol / EIA-ISO issue
    ok, my forst post...im alittle confused.
    Our memory was full on a M-Plus controller, which doesnt take much!
    I connected controller via DNC to CIMCODNC, and after a couple of days of looking for correct settings and params i managed to get them speaking.
    I copied all the files in Mazatrol format (they came across in a ISO-ish format), I tested sending one back, it went back in Mazatrol format.
    Then I erased all the programs to clear memory.
    Now I cant start up a NEW Mazatrol Program, only EIA/ISO is listed for selection, and when i go to send back a MAatrol program, it transfers into the control as a ISO-ish type program.
    Any thoughts would be appreciated!
    TIA
    Registered MrMazak's Avatar
    Dec 2007
    Just load the back up that you made of the parameters before changing them and you will be fine or put back the original values of all the changes you made.
    Sep 2008
    Ireland
    I only changed DNC User Parameters ... How would that affect ability to create Mazatrol Programs?
    Mar 2005
    Silicon Valley, CA
    You got something else changed if you lost the Mazatrol... You did make a copy of your parameters before you changed any of them right? Also, which control do you have?
    It's just a part..... cutter still goes round and round....
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-03-2012, 04:49 AM
  2. Mazatrol Macro callout issue
    By MrMazak in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-25-2008, 09:11 AM
  3. Strange serial comms issue
    By TLSupper in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-27-2007, 02:00 PM
  4. Mazatrol T4 goove cutting issue
    By ap-machine in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-10-2007, 08:33 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Industrial Hobbies (Support forum)
    Last Post: 04-07-2006, 04:19 PM
