| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hi all, I am trying to figure out a barfeeder that has been in our shop long before I started there and that never had been used and no one even knows how to use it. The Lathe is a SQT-250my with 640T controller. The barfeeder is capable of setting feed lengths and ejection lengths etc... I have gotten a lil start with the programming of it but have hit a wall and do not have a solution. My program looks like this matl info: ........ M code: 6 68 69 M code 7 edg face...... This program will get the chuck opend and pusher comes and pushes out bar, pusher retracts, closes chuck and then nothing. The green auto mode light is on but the spindle dosnt start and turret dosnt move.... Oh the turret will change to the first tool up but then just sits there after that. Im sure this programing is completly wrong. Hopefully someone here can help me out. Maybe even have a sample program to give me visual. Oh and if anyone has a good end of bar procedure to automatically load the new bar. Thanks in advance for any help. I really appreciate it. Jess |
This is the program used in an Integrex100 but should work in any machine with a SMW Spacsaver barfeed. I have included the TOPCUT program as this calls for the remnant ejection and faces off the new bar (theoretically you could just load a new bar and run without the face off but I play it safe) I have attached the .DOC file so you can open it there and get a better look at it. (I can't figure out the tool bar here to ajust the font size) Make sure the Program Offsets are the same on both the MAIN and TOPCUT. Good Luck. PNo. MAT OD-MAX ID-MIN LENGTH RPM FIN-X FIN-Z WORK-FACE MPX FIN-LENGTH 0 6061-AL 1.7 0. 4. 3500 0.015 0.005 0.05 PNo. MODE TYPE HEAD SPDL 1SEP SINGLE 1 <> PNo. CHANGE-PT GEAR TOOL 2MNP 1 GNL OUTH SEQ G DATA-1 DATA-2 DATA-3 RADIUS/VARIABLE RPM FEEDRATE M OFS 1 69 PNo. MODE #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 3 M 1 8 PNo. MODE RV FV R-FEED R-DEP R-TOOL F-TOOL 4EDG FCE 2000 2250 0.008 0.05 GNL OUTH GNL OUTH SEQ SPT-x SPT-z FPT-x FPT-z ROUGH 1 1.13 0.03 0. 0. 5 PNo. MODE # CPT-X CPT-Z RV FV R-FEED R-DEP R-TOOL F-TOOL 5BAR OUT 0 1.13 0. 2250 2250 0.012 0.11 GNL OUTH GNL OUTH SEQ SHP S-CNR SPT-X SPT-Z FPT-X FPT-Z F-CNR/$ RADIUS/A ROUGH 1 LIN C0.03 <> <> 0.75 0.39 <> 4 2 TPR 0.75 0.39 0.695 0.4 4 3 LIN <> <> 0.695 0.905 <> 5 4 LIN R0.005 <> <> 0.95 1.765 <> 0.005 5 LIN C0.015 <> <> 1.1 1.84 <> 6 6 TPR 1.1 1.84 1. 2.315 6 7 LIN <> <> 1. 2.6 <> 6 WorkNumber: 9999 TOP CUT Size (number of blocks): 13 Machine: Fusion640MT PNo. MAT OD-MAX ID-MIN LENGTH RPM FIN-X FIN-Z WORK-FACE MPX FIN-LENGTH 0 6061-AL 2. 0. 2. 2000 PNo. CHANGE-PT GEAR TOOL 1MNP 1 GNL OUTE SEQ G DATA-1 DATA-2 DATA-3 RADIUS/VARIABLE RPM FEEDRATE M OFS 1 5 2 9 3 6 4 68 5 565 6 7 7 4 X 2. 8 8 PNo. MODE RV FV R-FEED R-DEP R-TOOL F-TOOL 2EDG FCE 1500 1750 0.01 0.05 GNL OUTE GNL OUTE SEQ SPT-x SPT-z FPT-x FPT-z ROUGH 1 2. 0.1 0. 0.01 PNo. MODE COUNTER RETURN WK.No. CONTinue NUM. SHIFT 3END 2004 1 |
| Cost comparisons.... multi set up VMC vs mill/turn barfeed machine... | InspirationTool | Employment Opportunity | 3 | 05-17-2007 04:58 PM |
| citizenf20 lipe barfeed | wdzhere | General Metal Working Machines | 0 | 09-01-2006 06:36 PM |
| LNS Barfeed | Lazzer65 | General Metal Working Machines | 4 | 08-13-2006 04:22 AM |
| Barfeed Option | pinguS | Fanuc | 3 | 07-27-2006 10:26 AM |
| servo 300 barfeed | positiverake | Haas Mills | 12 | 02-14-2006 06:00 PM |
