Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-24-2008, 11:32 AM
apylus444 is on a distinguished road
T32 Losing position
Our Quickturn T32 will sometimes lose its X and Z positions (tool touch offs) only after powering it off and back on. Does anyone know why this could be? I would think that if it was the encoder then it would be all over the place. Thanks
Old 07-25-2008, 04:03 PM
Micwanho is on a distinguished road
One possibility is the mechanical limit switches that are used to home out the machine. If they are sticking it can cause the machine to home out at slightly different positions. Thus the value from home position to tool touch off will change.
Old 07-26-2008, 10:57 PM
bigbobomb is on a distinguished road
Check to see if it is off even amounts (such as 20,40, 60, thou. each time)
If this is so then you have a bad encoder. If it is all over and and never the same amount anytime your home reference switch is probally sticking, loose or the trip dog is loose.
x-axis losing position...??? shnitzel Servo Motors and Drives 11 09-29-2007 12:46 PM
Tormach losing Z position geomagnet Tormach PCNC 11 05-21-2007 07:05 AM
losing position in X martsto Milltronics 3 03-15-2007 08:55 PM
Losing steps - WHAT IS UP?!? Sporqster DIY-CNC Router Table Machines 10 04-27-2006 09:50 AM
