you should be able to use single process to run any given unit in the program.
I want to be able to call up and individual UNO and run it, only without changing the Priority No. in the program. Is this possible? Thanks
Apylus444
How do you find single process? I only see single block and restart. Our T32 lathe has a single process button on the control, but I can't find anything on the M2. Thanks
