Results 1 to 3 of 3
Thread: PROBE HELP!
    Jul 2008
    PROBE HELP!
    Hey guys. I am working on a Mazak VTC 200-B with a renishaw probe. I program the machine in EIA format and know no mazatrol at all. I was wondering if you could recomend a simple way for me to use the probe for setting my work offsets by picking up edges and measuring bores and such. I have figured out the manual measure option but would like to learn the right way. Any suggestions would be great. Thanks
    Mar 2005
    Silicon Valley, CA
    If its a factory installed Probe setup, then you should also have received the probe programming manuals. You did get the Inspection Plus software (Option depending on the machine age) right? So the probe macros should already be loaded in the machine. Look in this book. It shows in pretty good detail how to drive a probe in G code and set up the G65 routines and variables.
    Mazatrol probing is actually quite simple but I do prefer do drive them by G code...
    It's just a part..... cutter still goes round and round....
    Mar 2010
    Probe Help
    T30
    M6
    G90 G54 G43 H30 bla bla bla
    G65 P9810 X Y to safely move the probe into locations. (if probe hits it will not crash but stop instead).
    G65 P9814 (internal bore or external OD depending on z axis in call or not)
    G65 P9811 (one touch axis find x, y ,or z..)
    Good luck....
  1. marposs probe
    By reedmiles in forum Haas Mills
    Last Post: 12-29-2009, 12:14 PM
  2. Super Probe 17 Functions in one probe
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 01:46 PM
  3. Probe Shenanigans
    By Cory in forum Haas Mills
    Last Post: 01-12-2008, 10:30 PM
  4. Probe help
    By racear*2865 in forum Mach Mill
    Last Post: 10-16-2007, 02:30 PM
  5. CMM probe
    By sab in forum Open Source Controller Boards
    Last Post: 03-07-2006, 05:37 AM
