Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-01-2008, 04:06 PM
MJMark is on a distinguished road
M Plus Alarms
I am trying to get a HTC 400 with M-Plus control running after moving to another plant
2 issues
128 outside axis interlock when trying to MDI
101 Soft limit X axis when trying to home
105 Soft limit Z axis when trying to home
Any assistance would be appriciated - Mazak manuals are not the best
Old 07-02-2008, 07:32 AM
Leelund is on a distinguished road
MJ,
Found This:
M+ Soft Limit Reset
Go to Machine Paramerters
Machine parameter M8 (or m9 if needed)
1. Write down original M8 and M9 values.
2. Do one axis at a time.
3. Set problem axis to 99999999 (and -99999999 respectively)
4. Power cnc off/on
5. Now move axis towards home position until the axis decels and begins to move on it's own and reaches the home position
6. Go back and return the original values to each problem axis
7. Power off/on
8. Do the same for each problem axis.
Only warning is if axis are close to home positions jog minus to center axis stroke before performing above operation.
Your 128 axis interlock is generated by trying to go to MDI and not being homed. Should go away after homing.
Old 07-02-2008, 05:36 PM
Captdave is on a distinguished road
I had a similar problem with a T32 control after the memory battery went dead. After reloading the parameters, the Z axis would hit the soft limit well before it reached the home position.
Used the same procedure Leelund discribed (although different parameter numbers for the T32) and it worked like a champ!
Old 07-29-2008, 03:39 PM
Thanks Guys
Up and running
#105 & #163 alarms Greg 24 Haas Mills 2 06-17-2008 04:54 PM
ALARMS 250 and 251 Geof Haas Lathes 5 02-15-2008 09:32 AM
Fanuc 0t-C 409, 414, 424 alarms acerocket Fanuc 0 11-14-2007 09:47 PM
MULTIPLEX 420 Alarms CIMMaster Mazak, Mitsubishi, Mazatrol 3 08-06-2007 03:19 PM
Mazak T1 Alarms mbpp Mazak, Mitsubishi, Mazatrol 3 06-20-2007 11:27 PM
