Results 1 to 4 of 4
Thread: Mazatrol M32B RS232 from serial to printer port now
    Jan 2008
    HAVE TO SWITCH MY MAZAK RS232 CONNECTION FROM THE 9 PIN ON PC
    TO THE 25 PIN ON THE PC.
    Things not working now.
    Have the mazatrol M32B control.
    Also have the Mazak Data transfer program.
    Everything was working.
    What do I need to change on the PC and or in the Mazak.
    do I have to change my wiring on the cable to cross over.
    Used to come from Mazak 25 pin to PC 9 pin.
    now I plugged a 9-25 adapter and plugged to the PC
    printer port.
    Is it comm 2 now insted of comm 1 ?
    Dec 2006
    I hab the same problem
    Hello
    I had the same problem. I dont think the 9to25 pin adaptors are wired right. You will have to redo the pc end of your cable. My problem was I had a 25 to 25 pin cable trying to use the adaptor down to 9 pin to a laptop. Interestingly though if I ran through an a/b switch box that had a 9 pin input and 25 pin output and it would work.
    Jan 2008
    Quote Originally Posted by Cycle Start View Post
    Hello
    Quess I'll start there- makes sense
    Registered dcoupar's Avatar
    Mar 2003
    "Mazatrol M32B RS232 from serial to printer port now "
    If you're switching to the "printer port" on the PC... DON'T DO IT! The printer port is parallel, not serial, and will NOT communicate with the CNC.
  1. serial port
    By lamicron in forum Computers and Networking
    Last Post: 12-18-2007, 11:42 AM
  2. connecting a printer to a Mazak with serial port
    By z-zero in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-07-2007, 08:41 PM
  3. Okuma Cadet-Mate RS232/Serial port use?
    By brujo in forum Okuma
    Last Post: 06-21-2007, 08:35 AM
  4. rs232\serial port (Voltage)
    By j m in forum Computers and Networking
    Last Post: 08-05-2005, 08:43 AM
  5. printer port?
    By replicapro in forum General CAM Discussion
    Last Post: 11-26-2004, 04:37 PM
