| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
I need expets help. I need file transfer between Mazatrol T Plus and a PC with PC-DNC editor installed. I will very appreciated your help. I tired it only to get "515 CMT MIS-CONNECTED" messages. Here is details; 1.CNC machine (Mazak, Quick Turn 30, Mazatrol T Plus) 2. XP laptop with 9 pin serial port 3. PC DNC Editor (pretty new version, trial) 4. Serial Cable (9 to 25 cable, customised to support Mazatrol) My question: 1. I have A15 to A32 parameter information. There ,however,were Machine Parameters like X-1, Z-1, C-1, 4-1, 5-1 which one should I modify values? 2. For A29 and A30, what value should I input? Here shows cable spec and parameters I have: CNC side (25-pin) -------- PC side (9-pin) pin 2 ----------------------- pin 2 pin 3 ----------------------- pin 3 pin 5 ----------------------- pin 7 pin 7 ----------------------- pin 5 pins 6 and 8 ---------------- pin 4 This cable will work on all Mazak models, assuming that you have a 9-pin serial port on your PC. To configure your Mazatrol, you'll need to set several parameters. Here are our suggested settings: A15 - 206 (No parity, 2 stop bits, 8 data bits) A16 - 1 (RS232 parameter for serial tape?) A17 - 6 (CMT baud rate 4800) A18 - 6 (EIA baud rate 4800) A19 - 0 (Tape rewind code) A20 - 1 (Output ISO) A21 - 0 (Spaces between work # & data A22 - 0 (Spaces between programs) A23 - 0 (Leader / trailer in feet) A24 - 0 (Tape Vertical Parity Check = off) A29 bit 0 - 0 (Don't stop at O or A29 bit 1 - 1 (Stop at M02) A30 bit 0 - 1 (Serial reader on) A30 bit 1 - 1 (Serial punch on) A30 bit 2 - 0 (Parallel reader off) A30 bit 3 - 0 (Parallel punch off) Remember: Bit 0 is the RIGHTmost bit A31 - 109 ("#" code for EIA punch) A32 - 70 (":" code for EIA punch) Thanks, Young |
DEAR YOUNG, I HAVE A QUICK-TURN 10 WITH A T-PLUS CONTROL. I PURCHASED A PROGRAM WITH A CABLE FOR $220.00. IT WORKS JUST FINE TO STORE A PART PROGRAM ON YOUR PC AND THEN RESTORE IT TO THE MAZAK. THE PROGRAM IS "EZATROL" AT EZATROL.COM. YES MAZAK HAS A "UNIQUE" RS235 FORMAT, EZATROL THRU E-MAIL HELPED US SET UP THE MAXAK PARAMETERS ( AND YES I THINK MAXAK MANUALS ARE NOT WRITTEN VERY WELL ). I HOPE THIS HELPS WITH YOUR PROBLEM. PAUL |
| Need Help!- Mazatrol T32 File Transfer Software | JFinn | Mazak, Mitsubishi, Mazatrol | 5 | 03-18-2008 08:30 AM |
| Mazatrol/EIA file transfer | bz1801 | Mazak, Mitsubishi, Mazatrol | 6 | 03-29-2007 05:57 PM |
| File Transfer | roninB4 | CNCzone Club House | 3 | 08-27-2006 11:05 AM |
| file transfer | axis overtravel | Fadal | 13 | 01-26-2006 09:55 PM |
| EIA file transfer | grunemh | Mazak, Mitsubishi, Mazatrol | 0 | 12-02-2005 07:45 AM |
