Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-22-2008, 04:31 PM
rs1982 is on a distinguished road
eia subprogram
I need some help with a program that requires some thread milling. I need to make a threaded bolt hole pattern. Ive wrote the bolt hole circle using m-plus controll. Ive also wrote a thread milling program in eia that ive already proofed. My question is How do i thread mill all the holes in the pattern. I can go in and modify my thread mill cylce for each hole, but i know there's a better way can anyone help me?
Old 03-22-2008, 07:20 PM
MazakMikeO is on a distinguished road
Use the OFFSET unit to set the centre of each hole as X0 Y0 then call you eia program. Works a treat. You can get the X and Y values from the graphic screen if you leave the WPC at X0 Y0 and run it single step.
Old 04-10-2008, 08:54 PM
LarryA is on a distinguished road
I generally would create separate WCP lines for each hole then put duplicate units under them with a Manual program. I try to stay away from sub programs due only to the fact that Mazatrol will not allow you to do a restart at a sub program unit. At least neither of the two Mazaks we have will.
Old 04-10-2008, 09:42 PM
crazythunder is on a distinguished road
You could make it manual unit and then it would run like a eia program, but be a mazatrol program.
Old 04-11-2008, 08:10 AM
That's the way we did it, rewrite your EIA code into a manual unit and copy it using the offset units I mentioned above, that way you can restart if you need to run it again when sizing in.
Eia subprogram in mazatrol magneto259 Mazak, Mitsubishi, Mazatrol 3 04-10-2007 10:19 AM
having trouble with subprogram dshowald Milltronics 10 02-10-2007 02:32 PM
Restarting an EIA subprogram ajl6549 Mazak, Mitsubishi, Mazatrol 6 08-09-2006 06:06 AM
Fanuc 16T subprogram example?? stex Fanuc 11 03-27-2006 02:15 PM
Mazatrol subprogram BeanO Mazak, Mitsubishi, Mazatrol 5 11-24-2005 03:12 AM
