Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-06-2008, 09:36 AM
JFinn is on a distinguished road
Mazatrol T32 File Transfer Software
Looking for a file transfer software for upload/download from a Mazatrol T32 primariliy, but also want to communicate with a Acramatic 850SX, Siemens 810T, Fanuc OT, and AB 8600.
Currently have ProComm (DOS version) to communicate with a most controls, but I need to get a software to upload/download from the Mazatrol.
Ideally was looking for a software to communicate with the Mazatrol and some or all of the above controllers and eliminate the need for the old DOS ProComm.
I see Griffo Brothers is primarily for Mazatrol, but does anyone use it as a universal software. Others I am looking at are WinDNC (Greco) and PCDNC (Suburban). I believe they are suppose to be able to commucate with all including the Mazatrol, but wondered if there would be limitations.
Any suggestions from any users with similar situations welcome.
Primary function is for file backup.
Old 03-06-2008, 02:16 PM
psychomill is on a distinguished road
Click Here...
It's just a part..... cutter still goes round and round....
Old 03-12-2008, 05:45 AM
gyrodog is on a distinguished road
The only software that we could get to work other than the ridiculously expensive Camware was MultiDNC. You can normally download a trial version from their site www.Multi-DNC.com
The only problem is that it downloads in hex and cannot be read very easily. (Unless you can decipher hex) You can still send it back to the control without a problem.
The Multi-DNC cam communicate in CMT format as well as ISO/ASCII.
Remember to plug your cable into the controls Microdisk port and if the machine has the EIA option, plug the cable into the printer port which is normally mounted next to it. You will be able to edit and read the EIA format.
Old 03-12-2008, 05:48 AM
Me again, the microdisk port is used for the CMT format and the printer port for the EIA/ASCII format(G codes & M codes)
Old 03-12-2008, 01:06 PM
hgmorgan is on a distinguished road
We have used Griffo Bro. for all our machines (Mazak & others) for many years now and it works great.
Old 03-18-2008, 08:30 AM
vsengineering is on a distinguished road
Smile
Hi
I just got Griffo and it works ok with my Mazak and my Deckel (siemens 3m)
Vladimir
Free DNC RS232 software for serial file transfer bborb Machine Problems, Solutions , Wireless DNC, serial port 1 08-04-2007 06:28 PM
Mazatrol/EIA file transfer bz1801 Mazak, Mitsubishi, Mazatrol 6 03-29-2007 05:57 PM
File Transfer roninB4 CNCzone Club House 3 08-27-2006 11:05 AM
file transfer axis overtravel Fadal 13 01-26-2006 09:55 PM
EIA file transfer grunemh Mazak, Mitsubishi, Mazatrol 0 12-02-2005 07:45 AM
