Results 1 to 6 of 6
Thread: MAZAK QT10 & BAR PULLER
    Dec 2007
    I JUST PURCHASED A MAZAK QT-10 ( 1996 T-PLUS CONTROLL ) AND I WOULD LIKE TO USE A BAR PULLER BUT I GET A ERROR WHEN I TELL THE MACHINE TO OPEN OR CLOSE THE COLLET. THE ERROR IS ILLEGAL M CODE.
    DOES ANY BODY KNOW THE SOFTWARE CODE TO ENABLE THESE TWO M CODES
    THANKS FOR ANY HELP YOU CAN GIVE.
    PAUL
    Registered carbidecraters's Avatar
    Apr 2005
    Could it be your moving the turret at the same time?
    Feb 2008
    Check your electrical manual. I think it is parameter R49. I forget which bit of this parameter you have to change to allow auto chuck open/close.
    Registered MrMazak's Avatar
    Dec 2007
    Make sure you put an M5 in before the M6 line or the chuck will not open.
    Dec 2007
    THANK YOU SO VERY MUCH
    Quote Originally Posted by quickturngreg View Post
    DEAR GREG,
    Thank you very much!!! You were right R49 is the location to turn on a T-PLUS control. A freind of mine has QT-10 the same year as mine and he looked at the "R MACHINE CODE PAGE" and we found 6 differnces one being R49. So we changed R49 to "01001010" and now the open and close "M COMANDS" work.
    Somebody ought to keep a log of these "UNDOCUMENTED MACHINE CONTROLS".
    THANKS AGAIN!!!
    PAUL WILCOX
    MILWAUKEE
    Feb 2007
    Figured I would chime in and add that this is the parameter for the 640T Fusion control as well. I just used it on my '99 QT250HP.
    Thank heavens for this post, and google.
    1. problem with mazak qt10 t1
      By diz in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 11-12-2007, 11:24 AM
    2. Mazatrol t1 qt10 cpu problem
      Last Post: 10-17-2007, 08:29 AM
    3. Forklift ran into our little QT10..help!
      By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-19-2007, 09:15 AM
    4. Mini jaw puller?
      By mikesativa in forum General Metalwork Discussion
      Last Post: 04-18-2006, 12:21 PM
    5. Wheel Puller
      By TCAJAX in forum Fadal
      Last Post: 10-20-2005, 02:12 PM
