Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-09-2008, 09:43 AM
LTS LTS is offline
LTS is on a distinguished road
Mazak Slant 80 with T2
Is anyone out there running one of these machines? I have one that came from Japan with no parameters. Mazak have not been very helpfull.
Also does anyone have any experience with the M/T controllers?
Old 02-09-2008, 10:15 AM
Al_The_Man's Avatar
I can check to see if I have the parameters, I am not sure if it is a slant 80,
The usual problem with the M/T controller if you lose the battery, there are a few parameters that have to be reloaded via the on board dip switch.
There is a manual available written by a US Mazak tech, You may still be able to get a copy from Mazak.
Old 02-09-2008, 04:23 PM
LTS LTS is offline
Machine kinda runin
Ok so I messed around with the control and a parameter manual and got the machine running in a fashion. Now I need help with RS232. I have the FX17 board but it does not look like anything is coming out of control. I have the little led tester and I do not see much activity. I checked the FX17 and it appears to be set for RS232 not RS422.
Any Ideas?
I did compare parameters A15-A30 with a T3 control all are the same.
Old 02-13-2008, 10:19 AM
Al_The_Man's Avatar
The RS232 drivers have a habit of going out on these cards, I have replaced the IC's, I think they are the 75189 75150 and there is also a 26LS31
Old 02-21-2008, 08:38 AM
LTS LTS is offline
Lastest info
I tested the board in another machine and it worked just fine. I took board back to original machine and worked on this problem some more. Made all the parameters I could find in book same on both machines. Still same. Tested board output at board still nothing.
Are any of the "OP" parameters related to the RS232? Although the machines are very similar the "OP" parameters differ quite a lot.
thanks.
Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1' Haaatschi Machine Problems, Solutions , Wireless DNC, serial port 20 08-22-2010 12:55 AM
Freqrol FR-SX Mazak Mazatrol T4 Quick Slant 20 machinist360 Mazak, Mitsubishi, Mazatrol 3 01-02-2008 11:51 AM
cnc slant beds 65-295 General Metal Working Machines 1 08-14-2007 11:43 AM
mazak slant turn 40n intermax Mazak, Mitsubishi, Mazatrol 0 07-04-2007 03:16 AM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
