Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-06-2008, 08:58 AM
CNCMP Scott is on a distinguished road
Robot quirk...Multiplex 6200 (Y)
In our shop we have 6 multiplex 6200's 2 of which are Y axis capable.
One of the multiplex's has a robot quirk that I would like to duplicate on the other 5.
Here is the scenario. Normal operation with robot commands in machine, (mazatrol programming) when robot is reset, the top shutter doors open at the time the robot would normally come in, even though it has been reset. We have one machine that does not do this, and hasn't since the day it arrived from Mazak. With robot commands in the same places as the other 5 machines, this machine will complete part and the doors stay closed, unless the robot is running. If Robot is reset the doors stay closed. If robot is running they open and close like they are supposed to.
Is it a parameter? Could the program be written differently? Any Ideas as to how to duplicate this?
I have sompared parameters from one machine to the other, and even changed them to match, but to no avail.
Thanks in advance, I hope I explained what I am looking for well enough.
Old 02-06-2008, 09:48 AM
MrMazak is on a distinguished road
Smile
The robot has its own PLC that holds the parameters it uses so you cannot change them on your own. I had issues with a gantry that took Mazak months to figure out. They finally sent out the PLC programmer and got it fixed. My gantry is a stacker carosel but I think they all use the same basic hardware. I would call Mazak Florence and talk to engineering dept. maybe you have a different PLC version in one of your gantrys. My machine is a Fusion640T so maybe things are different on a Matrix.
Old 02-07-2008, 06:30 AM
Rich S is on a distinguished road
multiplex
Our Multiplex will always open the top doors no matter if the gantry is running or not. We always have to restart past the gantry code when the gantry is not being used (first piece). Now you have me curious.
Mazak Multiplex 6200 Rich S Mazak, Mitsubishi, Mazatrol 3 02-07-2008 03:09 PM
MULTIPLEX 420 Alarms CIMMaster Mazak, Mitsubishi, Mazatrol 3 08-06-2007 03:19 PM
Mathematical Quirk? Jim Estes BobCad-Cam 3 12-10-2005 11:26 PM
looking for an old kolemorgan 6200 boomer187um General Electronics Discussion 0 08-28-2005 04:51 PM
A small quirk with Mcode setup.. murphy625 CamSoft Products 3 04-03-2005 10:14 AM
