Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-02-2008, 08:38 AM
bob@apc is on a distinguished road
macros
hi all ,
i have a mill with a meldas 500 series controller that i need help with macros while using common variables.
heres what im doing,
i have similar parts, same zero, but want to be able to just change one variable and have the hole location move without having to edit program with each different part.
the way i do it now is as follows,,keep i mind this is for one part
#512=a (x)
#513=b (y)
c,d,e,f being my different hole locations
and my line will read
G90G0G73X#512Y#513Z-1R...Q...F...
what i want to do is something like this
(part 1 #501)
(part 2 #502)
(part 3 #503)
#501=1
IF[#501EQ1] then 512 = a and 513 = b
IF[#501EQ2] then 512 = c and 513 = d
IF[#501EQ3] then 512 = e and 513 = f
thanks for any insight
Bob
Old 02-03-2008, 08:39 AM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Hi Bob,
It looks like you've got it mostly figured out already. You just need to figure out how the branching works. The Mits controls don't allow IF - THEN statements, only IF - GOTO. You just need to structure your program sort of like this:
#501=1
IF[#501 NE 1] GOTO 10
#512 = a
#513 = b
GOTO 50
N10 IF[#501 NE 2] GOTO 20
#512 = c
#513 = d
GOTO 50
N20 IF[#501 NE 3] GOTO 100
#512 = e
#513 = f
N50 G90G0G73X#512Y#513Z-1R...Q...F...
M2
N100 (INVALID PART #)
#3000=1(INVALID_PART_#)
M2
Hope this helps,
Scott
Old 02-04-2008, 11:42 AM
thanks metl, that looks like my way to go with the control not understanding then statements
Some Smartcam macros dpuch SmartCAM 2 12-15-2009 02:56 PM
Help with macros afterburn25 Haas Mills 4 04-09-2007 08:19 AM
Macros cncfreak General CAM Discussion 24 05-06-2005 05:04 PM
macros toyoda General CAM Discussion 0 05-30-2004 04:56 AM
Macros MachineSMM General CAM Discussion 2 06-20-2003 12:41 PM
