Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-10-2008, 08:06 AM
cut more is on a distinguished road
Meldas MO operator manual
Can anyone help me find an operating manual for the Meldas MO control Please?
I just bought 2 and have no manuals at all. The machines are Leadwell VMC-O so if anyone has a manual for those I am interested in any info ie. Lubricants, etc.....
Thank you,
Cutmore
Old 01-10-2008, 08:36 AM
Gold Member
Caprirs is on a distinguished road
http://www.meau.com/eprise/main/site...anuals/default
Old 01-10-2008, 08:56 AM
Operator manual for Meldas MO
Caprirs,
I tried that site already, I could not find the operating manual listed for the MO/M2 control. Do you know if there is another control that I could try that would be close? I am new to Mitsubishi's.
Thanks for any help.
Cutmore
Old 01-10-2008, 09:11 AM
Gold Member
This is not what you need? http://www.meau.com/Files/BNP-B2240.PDF You need the manual that explains the screen layout, parameters, modes, etc.?
It might be worth calling Mitsubishi to ask if they have what you're looking for.
Old 01-10-2008, 09:19 AM
Operating Manual
Caprirs,
Thanks again,
Yes I am looking for how to run the control. Are you familiar with them? I just bought 2 vmc's with these controls and last night I was able to get the 1st machine to jog, Manually home, manually turn on the spindle but I could not seem to turn the spindle on in MDI? I typed in S200 M3, Then input, Then hit cycle start. There was a message telling me MDI read mode?
Does it sound like I am missing something?
(A clue Maybe)?
P.S. (capri rs) The Car?
Thanks,
Cutmore
Old 01-10-2008, 11:19 AM
Gold Member
The machine should have a mode select switch on the control panel. There are likely options for MDI, Memory, and Tape/DNC. On my Mitsubishi M3 machines, I have an MDI screen where I put:
Sxxxx M3;
M30;
Pressing Input saves the MDI program. If I press the Reset button, I have to go back to the MDI screen and press Input again to "re-save" the MDI info.
Yes, the car.
Old 01-10-2008, 11:49 AM
MDI mode
caprirs,
Thanks,
I was able to enter the code and save it. I wonder if I programmed a spindle speed that was too low. I am not sure if my spindles go to 4500 or 10k as the nameplate on the spindle motor (mitsubishi SJ 3.7A) has 3 lines, 1 says 1500rpm, the next says 4500rpm, the third says 10K.
Can the spindle on yours go from 0 up or is there a low-end minimum speed?
I had a '79 pace car with the turbo 4 and loved it, Damn! why did I sell that!
I have always thought the Capris were better looking than the 'stang though.
I checked out your web site, It sounds like we are in the same boat, I have a 2 car garage, in that I have a series2 cnc Bridgeport, 2 Leadwell Machining centers, a cnc router, cnc lathe, & miscellaneous other stuff.
I am working full time and have my company in the garage, (2nd full time job?)
Do you work full time as well or just for your self?
Sorry if I got to long-winded,
Cutmore
Old 01-10-2008, 06:04 PM
Gold Member
I think those spindle motor speeds refer to the power rating in KW at each speed. There should be another number next to the rpm. The motor should be a 10Krpm motor but you may have a pulley ratio that results in a higher or lower spindle speed. On my machines, the pulleys are 1:1 so I can run 10K at the spindle. Minimum spindle speed is about 50rpm. However, since my machines have M3 controls, there may be some differences.
I know most procedures are similar between the M3 and M500 series controls. It may be worth downloading the manual for an M3 and seeing how much difference there is.
If you like the early Fox Mustang/Capri, check out www.foureyedpride.com
My car: http://www.foureyedpride.com/caprirs Between my wife and me, we have '79 Capri, 2 '84 Capris, '85.5 SVO and an '85 GT.
The two machines are in the garage like yours. They provide approximately 60% of my income. I get the other 40% as a contract employee for a small shop.
Old 01-10-2008, 09:16 PM
123CNC is on a distinguished road
cut more,
I am new to Mitsubishi Meldas M0, fairly green all around with CNC. But I do have an M0 instruction manual, not being an expert, I will try to give you my best interpretation (and my machine is not powered up yet to verify live.
In the bottom two rows of the MDI screen is a message area. If in the "<Data Set>" commands can be entered and read-write out-into memory. If "NO SETTING" is in the message area, the codes are not yet executable, still programming mode.
After entering your commands or code, "DATA", and the final "M02" or "M30" command, depress the [INPUT] key. The message area should update to "SETTING COMPLETE" and the MDI operation becomes executable. Pressing "AUTO DRIVE" will begin execution.
Hope this helps, although my experience puts my suggestions somewhere down near "a stab in the dark."
Old 01-11-2008, 06:10 AM
Testing the new toys
Thanks for the help guys,
I was able to get the MDI to work last night.
I ordered the operation manual from Mitsu last night too. $76.38 hardcopy +$15 for overnight shipping, not bad!
I was able to get the toolchanger to move lastnight,not sure it did everything it was supposed to as I have no toolholders yet.
A weird thing started after the machine was running for a while though, All of a sudden the drives kicked out and the control locked up. I had to power off at the monitor to re-set. Then when I powered back on the screen was totally filled with caracters both english & japanese. I had to turn the power off to the machine for a while and re-start. Then I was able to re-home and jog. I was looking in the cabinet to see if there were any LED's lit and all of a sudden the drives kicked out again! I didn't do it I swear!
Anyone have any idea where to start to figure this out?
Any help greatly appreciated,
Cutmore
ID:	50435   Click image for larger version
Old 01-11-2008, 07:22 AM
Gold Member
I would start by checking for loose wires and cables. Shut off the power and try to tighten every screw on terminal strips, make sure all connectors are fully seated, and make sure no boards have wiggled loose. During transportation, the machine can be bounced around enough to make some loose connections. Also, check the incoming voltage to make sure you have 200-240VAC. A lot of controls will shut themselves off if the voltage is outside that range.
  #12   Ban this user!
Old 01-11-2008, 08:08 AM
caprirs,
Thanks,
I did start checking screw terminals last night, connectors etc. I am using a Rotaphase phase converter and will have to check the voltages tonight. I think I will clean the boards too, as I know the Bridgeports could develop current paths on the boards if they get too dirty.
I believe this is the same problem the prior owner was having and why I got the 2 of them for only $1200. The second machine I was told was for parts, but it looks like everything is there waiting to be re-installed. The newer machine (87 vs 86) is the one for parts. Hopefully I can figure out the problem and be running at least 1 of them. I just did a job on the Bridgeport last month that took ~1200 manual tool-changes in 2 weeks and I don't want to do that again!
P.S. I checked out your car. Looks good.
Thanks,
Cutmore
I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control vettespeed Bridgeport and Hardinge Mills 27 05-30-2012 08:21 PM
Acramatic 850 operator and programming manual buckie555 General CNC (Mill and Lathe) Control Software (NC) 2 03-18-2012 04:49 PM
meldas 50 manual breazr Mazak, Mitsubishi, Mazatrol 6 04-23-2008 06:05 AM
Hitachi HT20 Operator Manual needed, will pay! 80spit General Metalwork Discussion 0 07-08-2007 07:48 AM
Cnc/manual Operator & Programmer In North Nj elaganis Employment Opportunity 0 08-02-2006 07:17 PM
