Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-10-2007, 04:36 PM
Fred Raud is on a distinguished road
QT-28 t-32 X-axis re zeroing help needed
After we got the spindle conrtoler fixed, 2 months later the x-axis crashed into the end, blowing the plastic caps off the linear guides. These guides are discontinued. and $7000 from mazak (nsk ly45's) So in the meantime, learning from our prior mistake with the spindle drive, sent the servo motor and drive to Mitsu in TO. Turned out to be just the encoder on the end of the motor. $1200 and the tested the drive and servo motor, and sent it back.
We ended up making new endcaps on the mill, and replaceing all the balls in the guides (std .250 ball bearings)
Now my question is how do we go abouts setting the zero position , upper/lower limits or the x-axis??
T-32 quick turn 28 Mazak
Old 12-13-2007, 02:50 PM
BAUMACH is on a distinguished road
The upper limit is parameter A9 range -99999999 to 99999999
The lower limit is parameter A10 located under machine parameters.
Each machine may be set different: But ours is A9=2500, A10= -155000
Old 12-17-2007, 05:28 PM
Thanks!! ours is the same as well.. makin chips again"!
Old 07-31-2008, 02:28 PM
Shannon McCarth is on a distinguished road
Hi Fred!
My name is Shannon Mccarthy. I work for Herdeman Corporation in Cudahy, WI. We are having the same problem now as you did with the end caps blowing off of our QT-28. I see you ended up making your end caps. We are running into the same problems w/ Mazak & NSK and were wondering if you made extra end caps or can make more & if you would be willing to sell some to us. We could try and make them ourselves, but it would be more of a hassle than a help...and it would take us longer to get the machine back up and running. Please let me know if you can help us. Thanks in advance.
Strange results when zeroing z axis millbilly Mach Mill 5 06-29-2007 01:49 AM
Zeroing imported parts an0n Mastercam 4 01-10-2007 01:13 PM
Zeroing the dials? wildcat Industrial Hobbies (Support forum) 2 11-17-2006 05:53 PM
OK Zaxis Zeroing Technique - Benchtops/Mini/Bridgeports! bill south Benchtop Machines 17 09-17-2006 10:48 AM
Question about Referencing and Zeroing. redbaron Mach Software (ArtSoft software) 3 04-19-2005 12:34 AM
