Results 1 to 2 of 2
Thread: QT-200 Turret servo motor
    Registered andra's Avatar
    Oct 2007
    Malaysia
    Smile QT-200 Turret servo motor
    My QT-200 machine have alarm AL-20 on Turret controller (MR-J2_100CT), I think this encoder problem (OSA14), can I replace encoder only on servomotor (HC-SF-102) ? somebody can help ..me
    Apr 2007
    disconnect U V & W at the AMP. power the machine up. if alarm is still there, you have a bad Amp, if the alarm goes away,you most likly hve a bad encoder. you really need to put a MEGER on the motor to make sure the motor is OK.
  1. Servo Turret Issue
    By Tom Slick in forum Fadal
    Last Post: 03-03-2008, 11:34 AM
  2. FADAL 3016 Turret motor problem (geneva)
    By kentsui in forum Fadal
    Last Post: 10-02-2007, 03:14 PM
  3. Servo motor used as spindle motor?
    By fatal-exception in forum General Metal Working Machines
    Last Post: 09-14-2007, 03:55 AM
  4. HELP! need FANUC motor for my turret press
    By recycleroy in forum General Metal Working Machines
    Last Post: 09-28-2006, 03:19 PM
  5. Turret motor brushes on VFO
    By Greg Mueller in forum Haas Mills
    Last Post: 09-22-2006, 03:59 PM
