Results 1 to 4 of 4
Thread: T-Plus programming question??
    Jul 2007
    I am turning a shaft that requires a 4" radius and am having a problem with it under cutting about .010 at th start of the radius,...I know this will be hard to explain without the print but here goes...
    The shaft is 12"long, turned to 1.25",...... in the middle it is turned to .868 +- .002 for 6" with a 4"radius and .125 radius going up to the 1.25 Dia. on either side of the .868 Diameter in the middle.The 4" radius needs to start 1.0" from the 1.25 Dia. on both sides.
    I am using the "U" symbol in Bar Out, and 4" as the final radius, using seperate tools to make each side(one doing a back turn)
    any help would be appreciated!!!
    Registered CNCRim's Avatar
    Feb 2006
    it's hard to mental picture without the print, .010 undercut what I'm confusing.
    Jul 2007
    The .010 undercut is at the transition from the .868 turned Dia. to the start of the 4" radius.
    Jun 2006
    Could Be Tool Deflection... How Much Are You Leaving For Your Finish Pass?
  1. Programming question
    By g-codeguy in forum Fanuc
    Last Post: 06-05-2007, 07:16 PM
  2. Programming Question
    By toolmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-07-2007, 08:37 PM
  3. Fanuc 6m programming question
    By Yabbos in forum Fanuc
    Last Post: 05-30-2006, 01:10 PM
  4. BP Boss 6 Programming Question
    By spelunker in forum Bridgeport and Hardinge Mills
    Last Post: 03-21-2006, 10:05 AM
  5. Programming question
    By AMCjeepCJ in forum Milltronics
    Last Post: 01-10-2006, 10:58 AM
