Results 1 to 7 of 7
Thread: Mazatrol T4 goove cutting issue
    Aug 2005
    ... ok.. i just spent almost two days trying to cut a simple groove in a part on my QS 30 with a T4.
    Im not an expert in mazak programming but am able to do most. Made grooves before altho always seems like a challenge.
    Here it is:
    a .472 wide wide with an R.234 at the bottom ( an o-ring groove in a sence)
    .197 away from the face starting at 7.283 dia and ending at 6.811 dia
    Using a GROOVE OUT (blind , or closed ) option with trapezoid profile option, x starting point of 7.283, z starting point od .197, x finish point of 6.811 and z finish point of .197 with a end R of .234
    Im using a sandvik 6mm round insert holder and use GROOVE OUT tool geometry with .236 cutter width and a R.118 tool tip.
    Theoretically (as far as underestand) Mazatrol will automatically compensate for the TTR ( which is the best feature of mazak for me) and since the insert R is smaller than the part profile it should work - right?
    Well nomatter what i do it gives me an "invalid tool width in groove" error message.
    I tried to foul the controll by changing the tool widths and insert radiuses to smaller once and - for the most part - it will work in "figure check" but not in simulation or auto run....
    What am i doing wrong.....ma interpreting something incorrectly?
    Registered CNCRim's Avatar
    Feb 2006
    The problem I you have is because with groove with is .472wide and the R.234 if you multiple it by 2 it's way over .472 ...... there is your alarm come from.
    Aug 2005
    R.234 x 2 = .468 which is less than .472
    im going to try the G-code option and see if it works ... Any other suggestions?
    Feb 2006
    only .004 flat then, it must be your TPC. Change the overlap to 0 or .001 it should work, most Mazak overlap default as .010.
    Aug 2005
    i tried that.....as far as i can tell it is parameter U 38 ( Row U6 third column)
    I've changed it to several different settings including 0 and still no result.
    I also tried Manual Programming (we are pretty fluent here with G codes) and it seems everything works good but the G2 and G3 commands won't run .... "illegal G code input"
    Jul 2007
    ireland
    try not to put a radius into groove tool geometry leave it blank.
    Feb 2006
    Strange I try on my and it work fine..... maybe my is T-plus.
    1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
      By tuanpq in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 10-03-2012, 04:49 AM
    2. another turret issue
      By Paul in OK in forum Daewoo/Doosan
      Last Post: 05-24-2007, 12:21 PM
    3. Help with selector switch wiring issue (***actually a motor issue***)
      By BEDFORD in forum Industrial Hobbies (Support forum)
      Last Post: 04-07-2006, 04:19 PM
    4. THC Issue
      By Aldoseri in forum CamSoft Products
      Last Post: 01-31-2006, 05:33 AM
    5. Memory issue
      By nervis1 in forum Fadal
      Last Post: 06-23-2004, 06:47 PM
