We recently had a memory corruption and a drive controller for an axis go on a Mazak QT-C with a Mazatrol T1 controller. The service guy got instructions from Mazak to clear all the memory and re initialize it.
We had copies of the Programs written down before he did so, but do not have the T-SET and T-DATA info recorded. Also he input the parameters from when the machine was first built and the positions for the X and Z when turning the screen on are a lot different than what you normally get. They are huge like they were in metric or something instead of inches like they were before.
We go the machine from a company along with the part that was being machined, so we never actually programmed the machine, just knew how to adjust the cutting size from the program.
A few questions:
1) Is setting up the T-SET and T-DATA screens hard?
2) Can anyone give me instructions for setting those two pages up?
3) Anyone know if the machine would've came from Mazak in metric? And if so how to make it english again?
Unfortunatly we don't have an operation manual for the machine. And when we got the machine the programs and tools were already set up on it. Noone know's how to setup the machine, and the only thing ever recorded was the two programs we use, not the tool data.
Right now P16 is set at 1
than you should call your local Mazak dealer and give them manchine's model number and control they can send you a pdf....... that's what I did.
