Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-22-2007, 08:57 AM
Frankbals is on a distinguished road
Point to point programs
Hey all: I'm running a 3d program written in Tebis that is all point to point, so there is a lot of information for the h4800 Fusion control to take, and it is slowing way down when it is run. I called the tech support for Mazak, and he suggested using G61.1 , I tried it and it still is slowing way down. Anybody have a cure ?
Thanks,
Frank
Frank
Old 05-22-2007, 03:05 PM
psychomill is on a distinguished road
How tight are the points? If its real tight, it won't matter what control you're on, you won't likely hit the number since the machine is trying keep up with it. If G61.1 is still slowing way down, then it must be pretty tight. You can try G5 instead, but you need to have the Mazaac 3D option.
Other options: Repost the toolpath with looser increments if you can... repost the program to output arcs in all axis (XY, XZ, and YZ) to help some.... use Nurb Splines and let the machine calculate it (need Spline interpolation option).... or (since I don't know the shape or your part) reprogram and change the toolpath so its not using a billion lines of code to make the shape.
It's just a part..... cutter still goes round and round....
Old 05-22-2007, 03:12 PM
Hey psyco thanks for the reply, we don't have the G5 option (yet), and with Tebis it only does point to point, so we're loosening up the tolerance and reposting, hopefully that will help.
Frank
Frank
Point to Point Busellato Malacara CNC Machining Centers 3 05-01-2007 05:41 PM
Point Cloud jabuffi Digitizing and Laser Digitizing 9 12-03-2006 10:29 AM
set point command charper Rhino 3D 1 12-03-2006 04:40 AM
find the point? TURN ME General Metalwork Discussion 48 09-02-2006 11:15 PM
Point clouds kdoney Rhino 3D 3 05-21-2003 05:37 AM
