Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-21-2007, 04:45 AM
sting_dot is on a distinguished road
Mazak FJV 250UHS lubrication problem
I had lubrication problem with MAZAK FJV 250 UHS. When i try to run the machine, this error occured: IRREGULAR SLIDEWAY OIL PRESSURE. I'd tried to replace the lubrication pump to a new one. Same error still occured. Can anyone please help me? any suggestion.
1. where can i find the lubrication diagram chart for the machine?
Old 05-21-2007, 10:36 AM
little bubba is on a distinguished road
I had a similar problem recently on a QT20, same alarm. The oil valves that distribute the oil are probably clogged. Apparently you are susposed to replace them every year or two. For reference, there where 12 of one size and 2 of another on a two axis lathe. Total cost about $200 from Mazak. You can also cross reference and probably get them cheaper elsewhere.
Old 05-21-2007, 10:02 PM
mazak lubrication diagram
do you know where can i get the mazak lubrication diagram???????????????
Mazak VTC 41 memory problem kamran67 Mazak, Mitsubishi, Mazatrol 2 09-07-2008 06:57 AM
Lubrication bohica Industrial Hobbies (Support forum) 17 04-29-2007 01:13 AM
Mazak Mill Circular Interpolation problem DublJ Mazak, Mitsubishi, Mazatrol 2 02-13-2007 11:13 AM
CMT problem mazak t32-2 Enda Mazak, Mitsubishi, Mazatrol 1 02-09-2006 03:19 PM
