Results 1 to 6 of 6
Thread: 640M Thread Milling question
    Mar 2007
    Can anyone help with thread milling in mazatrol. In this particular case the thread is a 1 1/16-12
    I have tried to use the following procedure:
    1- in tool data eneter tool as tap 17s-16
    2- entered actual dia of thread mill into size Dia=.687
    3- Described tool as a Floting Tap
    Went into program Called up Tapping and set TPC Unit D49 to 0
    Unit nom major pitch tap dph chmf
    Tappng un17s-16 1.0625 .0833 .5 0
    tool nom hole hole-dep pre-dia pre-dpt rgh Depth
    Tapun17s-16 1.0625 .968 .75 planet ? fix p.0833
    returns message no tool in mag
    my question mark is(what is this block for?auto returns the value of .002)
    this is not C-SP or my F R
    Thanks for any help Ricky
    Jun 2006
    I think you have to use manual programming, write it out long hand and call your tool an end mill.
    A.J.L.
    Jun 2007
    you have to wrire a manual program. I have developed a "work sheet" style fill in the blank outline for thread milling in any mazatrol machine that is capable of it. It ramps in and ramps out and you can use it for taper pipe threads, or extra deep threads. let me know if you want a copy with instructions.
    Jun 2007
    Thread milling in Jenglish
    I've done it before. I'm going to try and get it going again today. It sounds like you are on the right track.
    I've gone thru all the books that I have and I have, that have not gone home with people and their good intentions to learn the control. The manual is real bad about being specific with the info and I still don't understand Jenglish. I don't know what is going on with the tool data. I'm sure you assigned the tool in tool layout first. I'll post if I get it to work.
    Professional Hack or Butcher
    Some Mazak knowledge
    May 2007
    Thread Milling
    Use a tornado mill cycle and put zero for the bottom finish to keep the last thread from being a complete circle. Tell your pitch the same as the thread pitch and set-up your thread mill as an endmill. This is the easiest way I have found.
    Jun 2007
    It works
    Tried it today, but didn't use the tornado.
    In a tapping unit you can select planetary for the tap. Just input the diameter in the tool data and you are good to go.
    The cycle works different than the tornado because it goes straight to the bottom of the hole and does 1.5 turns rather than heli cutting each thread. Try it, works good.
    1. mazak 640m circular tornado milling cycle
      By magneto259 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 04-20-2007, 01:03 PM
    2. Thread milling
      By wjfiles in forum General Metalwork Discussion
      Last Post: 01-08-2007, 05:13 PM
    3. thread milling
      By DavidC1949 in forum G-Code Programing
      Last Post: 03-30-2006, 01:27 PM
    4. Thread milling, can anyone help
      By jtrav in forum General CAM Discussion
      Last Post: 03-06-2006, 03:25 PM
