Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-31-2007, 03:54 AM
diz diz is offline
diz is on a distinguished road
problem with programming mazatrol t1
At least I turn on mazak and now everything is working !!
I have one question if someone knows the answer !!!
How to change(minimize) distance between work piece and tool while tool is getting out from the workpiece after mazak done threading cut(automatic mode) in hole (in graphic mode we saw that tool will crash into the bottom of the workpiece)
Best Regards
Old 04-04-2007, 06:20 PM
chips-ahoy is on a distinguished road
I am not sure about the T1, but this soundslike a case for "TPC" (tool path control). If control has TPC, use it as an option in the unit line, at the top of the TPC data you will see something like X backoff or clearence, simply reduce the value to a smaller number. These numbers relate to user parameters, you are simply changing these parameters for that unit only.
You can also manually drive the tool in advance or escape of the unit by changing the auto to manual and pluging in the data.
I hope this helps.
Old 04-04-2007, 07:00 PM
newguy81 is on a distinguished road
If I understand you correctly, you are threading the I.D. of a part?? And the tool will hit the bottom of the hole?? Shorten the thread Z final point. If you meant that it will hit the I.D. wall?? Be sure you are describing the minimum hole size on the first line correctly and that the tool data page has the correct tool diameter.
Programming Mazatrol T1 diz Mazak, Mitsubishi, Mazatrol 16 12-19-2008 05:17 AM
unresolved Mazatrol programming issues billder Mazak, Mitsubishi, Mazatrol 16 07-19-2007 08:42 AM
mazatrol cam m-2 programming maual h-15 balajieliza Mazak, Mitsubishi, Mazatrol 0 03-09-2007 07:06 AM
Mazatrol T32 Turret Clamping problem sunrock_83 Mazak, Mitsubishi, Mazatrol 5 02-08-2006 10:38 AM
Haas vs. Mazatrol 640 Programming fuzz5150 Haas Mills 1 04-10-2005 11:11 PM
