Results 1 to 5 of 5
Thread: Thru coolant QT250 pockets
    Registered Shotout's Avatar
    Jun 2006
    Question Thru coolant QT250 pockets
    What is the standard method of setting up thru the tool coolant in the pockets of a QT250? We bought some Kennametal boring bars with this feature and when I was looking at the pockets I didn't see a way to direct the coolant into the pocket with out rigging up some fittings and lines. That seems kind of cheesy to me so I figure I'm missing something obvious.
    Scott
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    Registered fizzissist's Avatar
    Apr 2006
    Its probably the toolholders....some toolholders have thru coolant provisions, like those for U-Drills, while most others have the external ports. I've got the same problem.
    Jun 2006
    OK, thanks. I'll check with Mazak for avilability of thru coolant pockets.
    Mark Twain
    Apr 2006
    ...Much as I love giving Mazak lots of money, there are other suppliers of toolholders out there. Check 'em out before buying them a new Bentley.
    Jun 2006
    Good point! 1.44MB floppy drive, Mazak's price: $363.80 plus shipping. Newegg's price 10.98 with shipping.
    Are there any brands you'd recommend? I've noticed the pockets on the turret are marked as is the turret by number. I assumed that they are matched at the factory. What about aftermarket brands. Is it necessary to somehow adjust them or should they be true to the centerline of the machine providing the turret is undamaged and aligned? when installed? I'm very new to this profession and appreciate your opinion.
    Scott
    Mark Twain
    1. pockets
      By raymond1 in forum Haas Visual Quick Code
      Last Post: 05-20-2007, 07:59 AM
    2. Open Pockets
      By big_mak in forum OneCNC
      Last Post: 08-04-2006, 12:45 PM
    3. Eliminating Pockets
      By robinsoncr in forum Rhino 3D
      Last Post: 06-27-2006, 12:21 PM
    4. G code for pockets . . .
      By D2theIzzave in forum G-Code Programing
      Last Post: 06-22-2005, 09:28 AM
    5. cutter comp in pockets
      By rayenginee in forum Mastercam
      Last Post: 05-19-2004, 10:59 PM
